Date/Time: Mon, 20 May 2024 01:27:40 +0000
number bars distorted when using delta volume on bar peroid type
View Count: 682
[2016-11-20 00:37:18] |
canyiah - Posts: 48 |
Hi Ive tried page up log view up, the tick setting is 0.01 and Im still seeing the delta volume bars distorted
distorted.png / V - Attached On 2016-11-20 00:33:20 UTC - Size: 161.38 KB - 255 views |
[2016-11-20 08:03:50] |
Refer to: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Scaling Numbers Bars: Adjusting Tick Size For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
