Date/Time: Sun, 19 May 2024 16:26:31 +0000
Intraday Monthly Chart Gap in Data
View Count: 692
[2016-11-08 16:39:11] |
User316362 - Posts: 210 |
on my chart - Monthly-Itraday candles start at 9/11 to 12/13. Then there is a gap to 9/16 and candles are there to 11/16. Any thoughts on how to get the missing Monthly based on intraday (Not historical) data? Delete and download doesn't work....using date range in chart settings doesn't work either. Continuous contract is set properly. SierraChart Data |
[2016-11-08 16:44:01] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
