Date/Time: Sun, 19 May 2024 06:11:10 +0000
Different Data Feed and Broker Execution on Same Chart
View Count: 758
[2016-11-04 19:46:16] |
Gary Lockwood - Posts: 16 |
I have both IQFeed and Advantage as a broker who uses a CQG login (with it's own data feed). What I'm trying to do is connect using IQFeed's data on a chart and have the orders routed to the Advantage account (with a CQG login). I am using an automated system on the chart that executes to the chart, so I cannot simply run two instances of SC and look at the IQFeed chart and then execute on the CQG DOM. Is this possible? |
[2016-11-04 22:32:47] |
This is supported and is documented here: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance To be clear, the chart data file from the DTN instance needs to be opened in the instance of Sierra Chart connected to your CQG account. Let us know if you need any help with this. The simplest way to do this though is to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-04 22:36:38
