Date/Time: Sun, 19 May 2024 06:11:48 +0000
Have Symbol in the Center of the Chart
View Count: 659
[2016-11-03 18:52:29] |
charlie - Posts: 8 |
Is there a way to set the symbol in the center of the chart in the settings? If not, is the way to do this using an custom indicator? Thanks, charlie |
[2016-11-03 19:35:43] |
This is supported with the new Symbol Display study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s369 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-03 21:21:24] |
Perfect. Thank you.
[2016-11-04 01:26:01] |
Acro - Posts: 436 |
Is there any way to substitute the long symbol name with a shortened or custom version of that text ? Eg instead of "FGBL1216-EUREX" could you have "FGBL" or "BUND" ? |
[2016-11-04 04:48:19] |
The only way to do this is to create a custom study or use the Stationary Text tool: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
