Date/Time: Sun, 19 May 2024 08:35:37 +0000
Diagonal dominant text colouring
View Count: 736
[2016-11-03 03:04:15] |
User19165 - Posts: 346 |
Hello, I've read and re-read the description of diagonal dominance on the number charts help page many a time and I'm still confused why the text is being coloured as it is being. I've set the thresholds the column #1 thresholds to be 100, 200, 500. From my understanding this should be 100%, 200%, 500%. The text colouring method is set to text on diagonal dominant side. These thresholds mentioned above, are they comparing the % from bid vs the ask volume 1 tick higher? Or what exactly are they comparing it with? I see many a case where the text is being coloured even though it is not 100% greater on the dominant side. With thanks in advance, MK |
numbars settings.png / V - Attached On 2016-11-03 03:03:44 UTC - Size: 39.86 KB - 248 views numbars chart.png / V - Attached On 2016-11-03 03:03:54 UTC - Size: 10.15 KB - 233 views |
[2016-11-03 03:44:31] |
Your understanding of 100% is wrong. For example 51/50 equals 1.02 which is 102%. Here is the relevant documentation: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#DominantSideColoring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
