Date/Time: Sun, 19 May 2024 04:36:55 +0000
Leaving blank space in horizontal scale so DOM is always visible
View Count: 720
[2016-11-03 00:14:20] |
User553714 - Posts: 184 |
Hi, I know you can do this but I just seem to find the setting; I would like to leave a defined gap from the latest bar to the edge of the scale so that the chart DOM on graph is always visible instead of having the recent bars merge into the DOM graphics if you just manually scroll. Regards. |
[2016-11-03 00:50:35] |
Acro - Posts: 436 |
Shift ALT F and then move your right arrow/cursor to achieve your required space and then Shift ALT F to relock that space into position
[2016-11-03 03:22:08] |
Refer to: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
