Date/Time: Tue, 14 May 2024 02:11:41 +0000
Chart Value Tool
View Count: 594
[2016-10-25 15:20:44] |
User26753 - Posts: 43 |
Whe I change from the hand tool to the chart values tool I see the cursor with the form of "+". The problem is that I see this "+" cursor in every of my four charts. Is it possible to see this cursor only in the chart I want to analyze?
[2016-10-25 15:53:17] |
Sierra Chart - Max - Posts: 5609 |
It looks like you have Global Cursor mode enabled: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) You will need to make sure that Tools >> Global Cursor On is disabled. Sierra Chart Support |
