Date/Time: Sat, 18 May 2024 21:06:18 +0000
New MIT Order from chart
View Count: 647
[2016-10-25 13:56:04] |
User104854 - Posts: 441 |
Hi. Is there a way that I can place an MIT order from the chart? I'd like to put the mouse on the price that I want to place the order, right click and choose MIT. When I do this now it lists limit, buy-stop-limit, etc but not an MIT option. Please advise. Thanks. |
[2016-10-25 16:58:03] |
Yes you just need to add the order type to the menu. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#EnteringOrdersFromTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-25 19:18:09] |
Nice. Got it. Thank you.
