Date/Time: Thu, 09 May 2024 16:11:06 +0000
Automatically marking large trades
View Count: 1401
[2016-10-13 19:57:26] |
User628042 - Posts: 8 |
Hi, Say i'm using a 2t renko chart. I'd like to see whenever the volume traded at a price 'bar' exceeds some limit. For example, I'd like to see whenever there are 400 or more contracts traded at any price. So I can see say, that 400+ contracts traded at $2000 at 9:30, $2001 at 9:45 etc. Is there a way to do that in Sierra. I looked at the docs but couldn't find anything. Apologies if I missed it. THanks. |
[2016-10-13 20:37:07] |
binaryduke - Posts: 360 |
The Massive Imbalance study within the emoji trading Order Flow Suite will do this and will work on numbers bars, candlesticks and Renko charts: http://www.emojitrading.com/massive-imbalance/ |
[2016-10-14 04:33:35] |
Yes this is supported by using the Numbers Bars study: Numbers Bars You need to set the Column 1 Background Coloring Method to Based on Volume Percentage which also supports comparisons to an actual value: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#VolumeTradesPercentage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
