Date/Time: Sat, 18 May 2024 14:45:14 +0000
IQFeed data with Gain/OEC trading
View Count: 754
[2016-10-12 19:59:49] |
DabbaDo - Posts: 146 |
I've been through the documentation several times and I seem to be missing something fundamental. My primary instance is connected to Gain/OEC In a sub-instance I can't connect to IQ Feed. So I started a separate instance and connected it to IQ Feed. I cannot figure out how to "point" the IQFeed-connected instance to the Gain-connected instance so I can trade with Gain using IQFeed data. (Yes, I know it would work better using SC Real-time data, but I have some reasons for using IQFeed.) Thank you. |
[2016-10-12 21:31:38] |
I cannot figure out how to "point" the IQFeed-connected instance to the Gain-connected instance so I can trade with Gain using IQFeed data. Follow the instructions here: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-12 21:32:13
[2016-10-12 21:32:26] |
We gave the incorrect link in the previous post. It is: Sierra Chart Exchange Data Feed: Integration with Trading Services Prior post was updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-14 04:22:03] |
If you really want to use IQ Feed it is supported, but it is not the preferred way and the documentation for it has been removed. The closest available documentation is here with Find Symbol: File Menu: Find Symbol (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-14 04:22:41
[2016-10-14 11:24:41] |
That is very helpful, thank you. I decided to stay with the Sierra Chart Exchange Data Feed.
