Date/Time: Sat, 18 May 2024 12:47:31 +0000
Question on Numbers Bars
View Count: 692
[2016-10-11 14:26:02] |
vrunrun - Posts: 53 |
Hi SC, 1) It seems that SC can only identify the price range/level from user defined compared threshold by either highlighting the background or coloring the text and you cannot do both. Am I correct? If so, can you make both identification methods available to users? i.e. I can highlight the background by defining "compare thresholds #1" and also color the text (volume) by "compare threshold #2"? 2. Can you add an additional volume filter to the background coloring/ text coloring method e.g. Diagonal Dominant side so that only the total bid/ask volume at certain price level that satisfy the criteria defined in "compare threshold" AND above a volume threshold will be highlighted or color texted? Maybe the above is do-able already. If so, please tell me how to do it. Thanks. |
[2016-10-11 17:27:51] |
1. Both are supported at the same time. There are separate Input settings for the background and for the text coloring. It is also possible to display up to three Numbers Bars columns per chart bar. 2. Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#VolumeFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
