Date/Time: Sat, 18 May 2024 12:27:21 +0000
Pointer tool
View Count: 886
[2016-10-10 19:15:53] |
User153928 - Posts: 35 |
Hi support team, on YouTube from infinity futures they have a video how to enable to show Y value and time boxes with pointer tool but I don't have that box on 1466 Sierra Chart if I go to tools-tool settings-chart values-I have show Y value and time boxes which I enabled but not with pointer tools, I'm sure it is somewhere I have been looking and looking but no luck please point me in the right direction so I can use that tool. Thank you Walter |
[2016-10-11 04:16:55] |
This is no longer supported. The current options are documented here: https://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValuesToolSettings There are quite a few options that allow you to configure the the Chart Values tool in various ways. For example, you can set it to always be on when the Chart Values tool is selected and disable the vertical and horizontal lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-11 17:41:16] |
Thank you that helped Walter |
