Date/Time: Sat, 18 May 2024 20:37:18 +0000
Re: want to buy this indicator
View Count: 641
[2016-10-06 09:39:21] |
neo269 - Posts: 2 |
hello can you pls help me identify this indicator & site from where I can buy it? Thanks https://pbs.twimg.com/media/CuEnnAoUAAE6gTe.jpg |
CuEnnAoUAAE6gTe.jpg / V - Attached On 2016-10-06 09:37:06 UTC - Size: 76.27 KB - 251 views Attachment Deleted. |
[2016-10-06 10:01:26] |
Sierra Chart has this and it is called the Numbers Bars study: Numbers Bars It is included with Sierra Chart service package 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-06 10:53:40] |
NumbersBars - Posts: 141 |
@neo269 That's number bar as SierraChart support replied. However, the text "int buy'/'no demand' below number bars are custom programming done by stoic, in short, proprietary.
[2016-10-06 10:56:01] |
neo269 - Posts: 2 |
Ok thanks
