Date/Time: Thu, 16 May 2024 08:13:31 +0000
Trade Window Attached Orders
View Count: 668
[2016-09-28 16:45:28] |
User635149 - Posts: 9 |
I have set an attached order with one target and a stop, but when I place my order there is no target or stop on the chart. This is only happening on my CL chart. Thank-you, Emily |
[2016-09-28 17:20:52] |
There are two possibilities. You have not set the option to Use Attached Orders on the Trade Window for the chart. In this case refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#SettingsNotApplying The other possibility is that you are not seeing the Target and Stop because they are out of range. In this case refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ViewingOrdersOnTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
