Date/Time: Sat, 18 May 2024 06:48:59 +0000
Can't See Bid Quantities
View Count: 923
[2016-09-28 12:36:20] |
bob7123 - Posts: 7 |
(I searched the forum first before posting but did not find a matching post.) Hi, I am seeing odd behavior in the DOM. A picture is worth a thousand words, so please see attached. Basically, the bid quantities are not showing up. I know the bids are there, because when I click the M button and choose "Draw DOM graph on Chart' I see green bars, but there is nothing in the bid (Buy) column. I don't know if any of this is relevant, but I have the latest build, I'm connecting to LMAX (tried Demo and Live) and it appears to occur across all contracts. Can you please advise on what I can do to resolve this? Thank you very much, -Bob[/i] Date Time Of Last Edit: 2016-09-28 12:37:27
BidProblem.jpg / V - Attached On 2016-09-28 12:35:39 UTC - Size: 88.13 KB - 313 views |
[2016-09-28 17:36:37] |
You need to add the Bid Size/Quantity column. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
