Date/Time: Wed, 29 May 2024 06:20:18 +0000
Ask/Bid Volume Difference Bars working inconsistently
View Count: 809
[2016-09-21 17:55:07] |
User299392 - Posts: 216 |
http://www.sierrachart.com/image.php?Image=1474480431668.png 2 identical chart types same symbol same time bars just one study in both i.e. above and they both exhibit different data. see image attached. The one on right is bad and will not change much. PLEASE HELP. |
[2016-09-21 18:09:34] |
Make sure the Volume Filtering is disabled on each of those charts: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VolumeFilter Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-21 18:13:03] |
Spot ON. THANK YOU! |
