Date/Time: Sun, 19 May 2024 13:52:32 +0000
Syncing clocks
View Count: 898
[2016-09-20 16:00:52] |
User577170 - Posts: 8 |
I have an inquiry regarding syncing my computers clock to SC's clock. Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-09-20 06:19:26 I always manually sync my computer clock to SC clock. This is something I do every morning as typically it is off by 1-2 seconds each. This is not a big deal to continue to do. I have a stringent structure around what time I start trading each morning and it seems as though the bars start early sometimes, say 06:29:58 instead of 06:30:00. Should I also be re-downloading and re-calcualting data once I sync both clocks? Thx for the help |
[2016-09-20 17:53:17] |
Yes. That would be a good idea.
[2016-09-21 14:29:44] |
Still having a problem even after re-downloading/recalculating charts. Is it possible for me to start session times at 06:31:00 in chart settings. The reason for this is I often have alerts from the 06:30:00 bar and it is overlapping to the 06:31:00 bar causing me to take the prior alert than the one from the new bar. Chart Session Times: Session Times |
[2016-09-21 14:44:07] |
Disregard the above, it affects my studies. Any idea on why the bar transition lags? Or any ideas on how I can overcome this?
[2016-09-21 17:33:33] |
This is not really clear for us, but it sounds as though this would be the relevant help topic: Https://www.sierrachart.com/index.php?page=doc/helpdetails4.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-21 20:14:55] |
Thanks for that. Ive attached a screenshot, TWS and SC are off by looking at the times. Is there any way to sync the clocks?
Private File |
[2016-09-22 06:02:49] |
No, there is no way to do this kind of synchronization to TWS. Sierra Chart has this command that may be helpful: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
