Date/Time: Sun, 19 May 2024 08:29:23 +0000
[User Discussion] - Studies>>Sub Graphs>>Name and Value Labels - add another horrizontal alignment optio
View Count: 1120
[2016-08-21 10:28:31] |
User13668 - Posts: 291 |
This part of SC documentation refers: Chart Studies: Subgraphs Tab >> Name and Value Labels In respect of point #7, is it possible to add another option in addition to 'Right' and 'Right Edge', say called 'Right Centre'? See my chart attached. I do not like lots of lines on my charts as it makes price action hard to read, so almost all the studies I use are set to only display the Subgraph name. I variously (randomly) set each study to either display the subgraph name to the 'Right' or 'Right Edge' in an attempt to stop them over lapping in the two effective columns of the Fill Space. However with some instruments like the ES that have a smaller daily range, I often get subgraph names overlapping resulting in one or more being obscured. If I had the option of 'Right Centre' I could set some studies to use the middle area of the Fill Space thereby reducing the chances of subgraph names over lapping. Thanks |
ES-201609-CME [CB] Renko 4-2-2-x _11 2016-08-18.png / V - Attached On 2016-08-21 10:28:14 UTC - Size: 45.19 KB - 282 views |
