Date/Time: Sun, 19 May 2024 11:19:24 +0000
P&L Column on Dom
View Count: 1208
[2016-08-19 20:45:00] |
User488039 - Posts: 114 |
Can you tell me how to make the P&L column on the Dom, currency rather than points?
[2016-08-20 01:15:55] |
Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOMPositionPLColumn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-20 01:26:18] |
Thanks for getting back with me. I was looking under Chart/Chart Setttings/Advance Settings where I changed the P/L and Daily P&L on the Dom. Thanks, I would have never thought of this. :)
