Date/Time: Sun, 19 May 2024 05:07:18 +0000
data streaming problem
View Count: 787
[2016-08-19 17:01:19] |
User538397 - Posts: 4 |
I installed the latest sierrachart on windows 8.1 running in parallels on osx mountain lion and the data will not stream in realtime. only get historical downloads. if I click disconnect and connect real fast, I'll get the latest data for the moment-then it stops again. Possible solutions?
[2016-08-19 17:15:17] |
What Data or Trading service are you using or do you wish to use? See this page for the list: http://www.sierrachart.com/index.php?page=data.php&CAID=def Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-20 15:21:16] |
I am currently subscribed to sierra charts data feed service package 3 under data/trade service settings
[2016-08-20 19:29:17] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-21 06:50:15] |
I have been using sierra charts realtime data feed with the the infinity futures platform for es futures for the last 5 years and pay a renewal fee online each month. I just switched all software to a new machine and no longer get the realtime data for es futures on the sierra charts.
[2016-08-21 11:11:17] |
Therefore, you need to follow through the TransAct setup instructions here: http://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
