Date/Time: Thu, 16 May 2024 06:48:46 +0000
Numbers Bars
View Count: 1069
[2016-08-15 22:47:26] |
User866531 - Posts: 14 |
Hi, I'm trying to set up Numbers bars with diagonal dominant text coloring. I'm after a 300% difference between the diagonals that prints the highest number in bold and changes the color. I thought I had it at one point but then noticed a few diagonals that were nowhere near 300% difference had also been printed. (EG - 481/768 on the diagonal) I've followed the documentation as best as I can but it still wont highlight the numbers bars as I'm trying to set them up. (Please see attached for pictures of the settings.) The colors I'm after is that: - it should turn from Yellow to Red on the Sell side when its 300% more then its associated Buy diagonal - it should turn from Cyan to Green on the Buy side when its 300% more then its associated Sell diagonal I have setup Column 1 Numbers Bars Text = Bid Vol x Ask Vol Column 1 Background Type = Background on Dominant Side Column 1 Background Coloring Method = None - Transparent Column 1 Text Coloring Method = Text On Diagonal Side Column 1 Range 3 Up Color = Cyan Column 1 Range 2 Up Color = Cyan Column 1 Range 1 Up Color = Green Column 1 Range 0 Up Color = Cyan Column 1 Range 0 Down Color = Yellow Column 1 Range 1 Down Color = Red Column 1 Range 2 Down Color = Yellow Column 1 Range 3 Down Color = Yellow Column 1 Compare Thresholds = 300 (%) Enable Diagonal Zero Bid/Ask Compares = Yes Highlight Based On = Ask Volume Bid Volume Difference Can someone please point out where I'm going wrong? |
Numbers Bars 1.PNG / V - Attached On 2016-08-15 22:23:31 UTC - Size: 40.3 KB - 282 views Numbers Bars 2.PNG / V - Attached On 2016-08-15 22:23:38 UTC - Size: 45.63 KB - 250 views Numbers Bars 3.PNG / V - Attached On 2016-08-15 22:23:43 UTC - Size: 40.86 KB - 261 views Numbers Bars 4.PNG / V - Attached On 2016-08-15 22:23:52 UTC - Size: 41.25 KB - 287 views |
[2016-08-16 05:21:47] |
Provide a Chartbook that contains a single chart with this Numbers Bars study. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-16 12:22:34] |
Hi, Please see attached chart with Numbers bar study applied. Thanks |
Private File |
[2016-08-17 20:18:55] |
We apologize for the delay with this. We are going to be testing this Chartbook today and seeing what changes need to be made.
[2016-08-18 05:45:03] |
Corrected Chartbook is attached. Here are instructions to use it: http://www.sierrachart.com/index.php?page=doc/Chartbooks.html#UsingChartbookProvidedBySierraChartSupport Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
Sierra Charts Support.cht - Attached On 2016-08-18 05:44:41 UTC - Size: 29.71 KB - 247 views |
