Date/Time: Tue, 14 May 2024 12:08:58 +0000
Some of my charts are updated and some aren't
View Count: 576
[2016-08-15 15:57:45] |
User90927 - Posts: 38 |
T Bonds and Cattle are not updating on the charts whereas Oil, Copper Soybeans and Hogs are updated to the current minute. I have tried to disconnect and reconnect but it doesn't work |
[2016-08-15 16:02:32] |
There is a yellow band which just says Waiting to download historical data |
[2016-08-15 16:37:15] |
The first thing we need you to do is update to the current version of Sierra Chart following these instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate If there is any missing data in your Intraday charts, then follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
