Date/Time: Sat, 18 May 2024 04:04:53 +0000
Difference between two symbols
View Count: 1372
[2016-07-30 23:08:14] |
User28682 - Posts: 233 |
What study is used to plot a line of the difference between two symbols? study subgraph difference? If so I cant quite figure it out. I assume i need the two symbols in one chart? Ex: I want to see the difference, plotted as a line, of (AMZN - GOOGL) Thanks Tom |
[2016-07-31 05:13:41] |
You need to use the Difference (Line) study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-31 06:55:03] |
Thanks, that works...Two additional questions: 1) can I invert this graph I have created? make the highs lows and lows highs? 2) can I now make a moving average of this difference line I have created? Thanks! Tom Date Time Of Last Edit: 2016-07-31 06:56:34
difference.png / V - Attached On 2016-07-31 06:56:24 UTC - Size: 36.95 KB - 281 views |
[2016-07-31 08:52:51] |
1. You could try inverting the prices of each chart using this Chart Setting and see if that accomplishes what you require: Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) 2. You need to use this Study Setting: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
