Date/Time: Sat, 18 May 2024 12:03:12 +0000
AskVol BidVol Diagonal Difference Percentage
View Count: 1462
[2016-07-30 22:57:37] |
User381102 - Posts: 7 |
Hello, First of all here are the settings https://s31.postimg.org/uavvgv18r/image.png Could you please explain why there are no bars at several occasions using background coloring method "AskVol BidVol Diagonal Difference Percentage" of Numbers bars study? https://s31.postimg.org/l4c8v1r4r/image.png Also I don't fully understand the calculation and as such I don't quite understand the coloring in background type "Volume Profile". https://s31.postimg.org/8atrolj0r/image.png Thank you. |
[2016-07-30 23:31:48] |
The version I'm using is SC 1445.
[2016-08-01 10:33:11] |
Regarding the questions, refer to the updated documentation here: Numbers Bars: Numbers Bars Background Coloring Methods Specifically refer to item 9 in the Numbers Bars Background Coloring Methods section. Let us know if you have further questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
