Date/Time: Tue, 10 Feb 2026 02:50:00 +0000
Draw a Line Automatically 4 point above/below Current Price
View Count: 1095
| [2016-07-28 16:53:21] |
| User260560 - Posts: 37 |
Hi I'm trying to figure out how to do this - i use 4 point stop, and like a line to be drawn automatically 4 point above and below from the current price and updates with the price, to check if my stop/target will have support/resistance in front of it. Could you give me some idea how to achieve this? Much appreciated!
| [2016-07-28 17:28:39] |
Use this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s283 Use a negative number to subtract from the current price. We recommend using the Line at Last Bar to Edge Draw Style: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-28 17:28:55
