Date/Time: Fri, 10 May 2024 05:40:12 +0000
hourly $TICK and $ADL
View Count: 1060
[2016-07-24 06:36:39] |
User392091 - Posts: 1 |
Hello board, is it possible to display shorter time frames for the $TICK than daily, e.g. hourly or 5 min $TICK? I am also trying to use the advance-decline-line feature - but just get a straight line with unreasonable values - is there some secret? Thanks for a hint - Regards, Alex |
[2016-07-24 07:13:04] |
That is not the correct market statistics symbol. Make sure you are using the correct symbols which are documented here: Sierra Chart Market Statistics Also, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s151 For bar time frames below 1 Day you just need to open an Intraday chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
