Date/Time: Wed, 09 Sep 2026 09:21:21 +0000
FP Markets LMAX
View Count: 2086
| [2016-07-21 12:02:06] |
| rustrader - Posts: 7 |
Hello, FP Markets is an australian broker, which partnered with LMAX and gives clients access to it's liquidity. LMAX does not accept individual clients from Australia. https://www.lmax.com/press-centre/access-to-the-award-winning-lmax-exchange-is-now-available-through-fp-markets-the-leading-australian-broker Is it possible to get a connection through Sierra Chart in this case? |
| [2016-07-21 16:52:33] |
We will ask LMAX about this.
| [2016-07-21 23:31:06] |
Would be much appreciated. Thank you
| [2016-07-22 00:32:28] |
LMAX has been contacted. We will see what they say.
| [2016-07-29 04:36:44] |
I am guessing there was no response from LMAX...
| [2016-07-29 04:59:39] |
We did hear from LMAX, and there is no simple solution to this. We have no ability timewise to get involved with anything new at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-29 05:00:04
| [2016-07-29 05:24:24] |
Not a problem. Thank you
