Date/Time: Sun, 19 May 2024 05:43:29 +0000
Market depht historical graph, no numbers on each bar
View Count: 624
[2016-07-11 18:40:53] |
ibabeos1 - Posts: 6 |
Hello, Pre release 1443. With this studies, is possible to draw the last number on the dom, on the graph like a footprint. Settings study seem ok but it doesn't work. See my screen shot. What is ht egood parameters ? i reboot, click on reload and recalculate, doesn't work I'm on a 1 seconds graph on this link, you can see what i want to do (screen on the first post) Market Depth Historical Graph Range charts Date Time Of Last Edit: 2016-07-11 19:14:32
probleme sierra.PNG / V - Attached On 2016-07-11 18:40:41 UTC - Size: 102.21 KB - 229 views |
[2016-07-13 05:52:24] |
If you want to display the Market Depth quantities in the scale area on the right side of the chart, follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
