Date/Time: Sat, 18 May 2024 19:50:59 +0000
Market Depth Historical Graph Trial Access
View Count: 965
[2016-07-06 21:07:23] |
User624476 - Posts: 31 |
Hello, I am evaluating package 5, but I am receiving the following message when adding Market Depth Historical Graph. Version 1437. "Market Depth Historical Graph | Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package." Thanks in Advance. |
[2016-07-07 04:33:49] |
At the present time you will need a direct account to access this feature. Follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-12 00:13:12] |
User434275 - Posts: 2 |
Hello Engineering, Is this likely to be fixed in the future? The link is not an acceptable solution for those with affiliated accounts. The market depth is a fantastic feature to add so well done on that. |
[2016-07-12 06:08:15] |
Yes, this may be solved but why is it not an acceptable solution to have a direct Sierra Chart account?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-13 03:43:40
[2016-07-12 19:53:26] |
So the solution is to install sierracharts again, manually copy over files and pay sierracharts directly for a service which I'm paying for anyway? And all this for an indicator which was developed by a generous member on futures.io which sierracharts have renamed? I think my comment is more than justified. |
[2016-07-12 20:51:59] |
You do not have to install Sierra Chart again or copy any files. Simply create your own Sierra Chart account and log in with your own account following these instructions: http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#DifferentAccountName for a service which I'm paying for anyway?
Cancel what you are paying through your broker.for an indicator which was developed by a generous member on futures.io which sierracharts have renamed? This is not true even in the slightest. There has been extensive work developing this study in Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-12 20:52:16
[2016-07-12 21:10:59] |
There is no way for any outside developer to develop the underlying capability for complete access to and historical storage of market depth data. This functionality in Sierra Chart is very sophisticated, efficient, extensive and has been perfected over years of development. And also there is no outside indicator which can display the historical market depth data as fast and efficient as a built-in study can. Additionally, the attention to detail for the functionality Sierra Chart provides with and related to the Market Depth Historical Graph study, is very extensive. Any outside developed study is not going to come close to the level of quality and reliability and efficiency compared to what we offer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-12 21:15:15
[2016-07-12 21:11:34] |
The instructions here explain what needs to be done: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html The step about installing Sierra Chart has been updated specifically to clarify one of the issues you raised. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-12 21:11:57
