Date/Time: Mon, 13 May 2024 03:32:53 +0000
holes in the charts
View Count: 683
[2016-07-03 08:11:44] |
User27701 - Posts: 9 |
Every day the holes in the graph occur. They begin at the time when I switch off the Platform and the End at two o´clock of Central European Time. The upgrade to the actual version of Sierrachart 1434 didn´t help. This problem has started three weeks ago. My datafeed is Rithmic. You can see it in the picture.
Screenshot - 30. 6. 2016 , 15_33_15.png / V - Attached On 2016-07-03 08:11:36 UTC - Size: 97.25 KB - 246 views |
[2016-07-03 22:20:33] |
Refer to the response here: Every day the holes in the graph occur Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
