Date/Time: Sun, 19 May 2024 07:51:56 +0000
Additional copy of Sierra Chart
View Count: 599
[2016-06-28 18:21:17] |
User549604 - Posts: 27 |
I have a paid subscription for Sierra Charts. I am changing brokers to AMP Futures who supply a frere copy of Sierra Charts. I obviously have a copy of Sierra Charts on my computer with defined Chartbooks etc that I'd like to use for trading. What would you suggest is the best way to load the new copy of Sierra Charts from AMP Futures, and not overwrite my current copy and lose the information? |
[2016-06-28 18:23:39] |
You just have to log in with the Account Name: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-28 18:26:18] |
Into my current copy of Sierra Charts? The one that I'm paying for? What happens when the subscription expires this month, it's free with AMP
[2016-06-28 18:33:36] |
Yes that is correct. Nothing will happen when the subscription expires because you would not be using your directly paid for Sierra Chart account any longer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-28 18:35:04] |
Back to my original question: If I load a new copy of Sierra Charts from AMP on my computer will it overwrite the current paid copy I'm using? And will I then lose my data from my current copy?
[2016-06-29 05:09:30] |
No. No.
