Date/Time: Sun, 19 May 2024 02:58:09 +0000
How to I enable Status Bar
View Count: 594
[2016-06-28 18:09:23] |
User85876 - Posts: 15 |
I downloaded a newer version and I do not see anywhere to enable the status bar. Can you please tel me how to enable it.
[2016-06-28 18:14:24] |
The status bar has been removed. Refer to: New Control Bar to replace ToolBar and Status Bar | Post: 66601 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
