Date/Time: Sat, 18 May 2024 09:27:05 +0000
Setting up two alerts
View Count: 868
[2016-06-23 02:50:48] |
User292365 - Posts: 20 |
Hell, can I set up two alerts? Since I don't know if price is going up or down, can two alerts at the same time? One alert goes off if price goes above a certain price; and the other alert goes off if price drops below a certain price. I tried writing the code: =C<price here =C>price here But the alerts do not go off. The alerts ONLY go off when I have just one entry. Thanks for the support! |
[2016-06-23 05:36:30] |
Refer to: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#ORANDFunctions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-26 22:27:59] |
Willson - Posts: 176 |
I will soon be trying to do the same task. Considering the above SC post, it seems they are implying that it can't be done with simple alerts (my interpretation). So I am thinking of two approaches: 1 Set up two exact same indicators but with different alert conditions on each (one for shorts, one for longs). Or, 2: do same thing using two identical charts using different simple alerts. Does anyone agree that these solutions are workable? Or is there a better way? Thanks |
[2016-06-26 22:30:59] |
You can do this by using the OR function. So you can use a single Alert Condition Formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
