Date/Time: Sat, 18 May 2024 10:21:39 +0000
Opening Intra-day chart for the US-Dollar Index & difference between two US Dollar symbols
View Count: 1627
[2016-06-20 21:34:23] |
User292365 - Posts: 20 |
I am able to open the Historical chart with no problems. But as soon as I lower my time frame below a daily time frame, the chart is not visible - all I see is a blank screen, the chart disappears. Can you please refer me to the sierra link that can help me with this? Also, What's the difference between F.US.DXEU16 and USD-X? Is the F.US.DEXU16 the tradable symbol? If so, what would be the USD-X, a chart that allows me to look at the price movement but won't allow me to trade? |
[2016-06-21 02:03:53] |
Follow the instructions here to update the Symbol Settings: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings The US Dollar Index symbol is USDX. F.US.DXEU16 is a CQG dollar index futures symbol. USD-X is an FX Index symbol. Unless you understand exactly what it is we do not recommend using it. More information about it is found on this page: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php Although the calculation method is not thoroughly documented yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-21 02:07:37
[2016-06-21 04:45:29] |
Hi, thank you for your speedy reply. I still cannot see the intraday chart for the US Dollar Index. I read the info on the different sierra web pages (http://www.sierrachart.com/index.php?page=doc/helpdetails3.html) I am using CQG (Fix trading) for data. I understand the US Dollar Index is coming through ICE. I can see the Historical charts with no problem (Daily time frame and up). But when I go to a 60min time frame, the screen goes blank. --------------------------------------------------------------------------------------------- Below is the message I'm getting in the log: Software version: 1426 | 2016-06-21 00:44:35 Uses New Spreadsheets | 2016-06-21 00:44:35 Usage end date: 2016-07-03 | 2016-06-21 00:44:35 Enabled for: Advanced Features. | 2016-06-21 00:44:35 Enabled for: Sierra Chart Historical Data Service. | 2016-06-21 00:44:35 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-06-21 00:44:35 Current selected Data/Trading service: CQG FIX Trading | 2016-06-21 00:44:35 Chart Update Interval: 500 | 2016-06-21 00:44:35 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-06-21 00:44:35 2016-06-21 00:44:35 Local computer time | 2016-06-21 00:44:35 2016-06-21 04:44:35 Local computer time in UTC | 2016-06-21 00:44:35 2016-06-21 00:44:35 Local computer time in SC Time Zone | 2016-06-21 00:44:35 2016-06-20 08:09:20 Server time in UTC | 2016-06-21 00:44:35 Local computer UTC time and Server UTC time difference: 9 seconds. | 2016-06-21 00:44:35 Program path: C:\SierraChart\ | 2016-06-21 00:44:35 Data Files path: C:\SierraChart\Data\ | 2016-06-21 00:44:35 OS Version Number: 6.2 | 2016-06-21 00:44:35 Locale Setting: C | 2016-06-21 00:44:35 F.US.DXEU16 [CV] 60 Min #1 | Reloading chart. | 2016-06-21 00:44:40 F.US.DXEU16 [CV] 60 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.DXEU16.scid | 2016-06-21 00:44:43 |
[2016-06-21 05:30:11] |
Unless you are paying the USD110 exchange fee for the ICE you will not get any data for this. Refer to: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#MarketDataAuthorizationsForSymbols We had thought the problem was with the US dollar cash Index symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-21 05:33:03
[2016-06-21 05:55:19] |
ah that helps Thank you. Also, I am able to open USDX and drill it down to the minutes and hourly time frames. Is this symbol tradeable? |
[2016-06-21 06:05:56] |
No that is not a tradable symbol. Just market data only.
[2016-06-21 06:32:16] |
thanks. I'm new to Sierra Chart. I really like this board messaging thing :D Keep up the great work! |
