Date/Time: Sat, 18 May 2024 19:03:44 +0000
CQG Symbol mapping - F.US.EDAS12H20
View Count: 1413
[2016-06-20 19:15:51] |
Laurent1 - Posts: 15 |
Hi, I am trying to get data for the following spread symbol: F.US.EDAS12H20 but this doesn't work. I have to enter F.US.EDAS12H00 to get it to work: http://www.sierrachart.com/image.php?Image=1466449913943.png However when I try to trade this, I get a reject from CQG: "Commodity is disabled for trading at this time." So I had to log into CQG Simple Trader to enter the trade and then logged back in to check what symbol to use and it appears that F.US.EDAS12H20 is correct. Could you please advise on how to deal with this issue? Thanks |
[2016-06-21 02:08:11] |
The correct symbol to use will be the one that is providing market data. We need to ask CQG about this: However when I try to trade this, I get a reject from CQG: "Commodity is disabled for trading at this time." Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-21 18:04:02] |
This is from CQG: The symbol EDAS12H00 would imply the year 2000
In the attachment is the current listing of 12 month spreads Let us know if those given symbols work for both market data and trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-21 18:04:28
CQG spread symbols.png / V - Attached On 2016-06-21 18:03:58 UTC - Size: 47.68 KB - 279 views |
[2016-06-21 18:06:48] |
In addition to the information given in post #3, if a two digit year is actually required you should use 20 for the year 2020. Although we can see that you have used this and you say it does not work. So not totally sure about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-21 18:08:24
[2016-06-21 20:17:30] |
Thanks for checking this with CQG. It seems that there's a mapping problem here as for me: -- EDAS12H00: this gives me the data for EDAS12H20 but is not tradable -- EDAS12H20: this doesn't give me any data so I can't trade it Is this a problem with SierraChart or is this with CQG? Not sure what to do here to unfortunately... |
[2016-06-22 16:38:54] |
Hi, I have a similar problem with F.US.EDAL12M18, I get data with F.US.EDAL12M8 but this is not tradable, and do not get any data with the normal symbol: http://www.sierrachart.com/image.php?Image=1466613392290.png Any ideas on what is happening? Am I the only one with CQG having these issues? Thanks |
[2016-06-22 17:08:44] |
We need to do some testing of these symbols and then report this information to CQG. This will be done today.
[2016-06-23 05:46:09] |
We tested both of the symbols. Here is the result for: F.US.EDAS12H20 CQG WebAPI | Received symbol resolution report for: F.US.EDAS12H0. Search Symbol: F.US.EDAS12H20 | 2016-06-23 01:40:56 * CQG WebAPI | Received symbol resolution report for symbol F.US.EDAS12H20. Request ID: 990820. Contract ID: 1. | 2016-06-23 01:40:56 We received market data and could trade it. No trouble at all with either symbol. Therefore, use the symbol that contains two digit years and provide us the FIX log when you get the order rejection. Here are instructions: http://www.sierrachart.com/index.php?page=doc/helpdetails79.html Privately attach it here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-23 10:47:45] |
Thanks for checking. Regarding EDALM18, I logged in CQG Simple Trader submitted an order and then logged back in Sierra Chart. Got a fill and tried again and it worked... Attached are the log files for the past few days. Thanks |
Attachment Deleted. Private File |
[2016-06-23 13:23:14] |
It seems that I'm having issues to get data every time that I add a new symbol not sure why though... Is this due to CQG or my setup? I have to log into CQG Simple Trader enter a trade, log back into Sierra and cancel the trade, very weird... http://www.sierrachart.com/image.php?Image=1466688313699.png Date Time Of Last Edit: 2016-06-23 13:25:58
[2016-06-23 17:43:34] |
There should be an initial price. What specific symbol did you have a problem with? Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-23 17:43:51
[2016-06-23 19:02:59] |
We looked at one of the errors in the FIX log. It happened for the F.US.EDAS12H00 spread symbol. But that is not the right symbol. Make sure you are using the correct spread symbol and if you have a problem with market data, let us know the symbol and then provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-23 19:14:39] |
Well I was trying different symbol as the correct one doesn't work... See my last request for F.US.EDAS12H20: CQG FIX Trading | Using primary service for historical data for F.US.EDAS12H20 | 2016-06-23 15:13:49 F.US.EDAS12H20 #9 | Reloading chart. | 2016-06-23 15:13:49 F.US.EDAS12H20 #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\Laurent\Google Drive\SierraChart\Data\F.US.EDAS12H20.scid | 2016-06-23 15:13:49 Unsubscribed from market depth data for F.US.EDAS12M19 | 2016-06-23 15:13:50 CQG FIX Trading | Requesting market data for F.US.EDAS12M19 | 2016-06-23 15:13:50 Requesting market depth updates for: F.US.EDAS12H20 if supported. | 2016-06-23 15:13:50 CQG FIX Trading | Requesting market data including full depth for F.US.EDAS12H00 | 2016-06-23 15:13:50 |
[2016-06-24 02:44:44] |
Update Sierra Chart to the current version following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Use the correct symbol with the two digit year and when you have a problem of some kind, let us know what the problem is and provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We must see the entire Message log. Not a portion. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-24 12:54:47] |
Thanks, see logs below: Software version: 1433 | 2016-06-24 08:52:50 Uses New Spreadsheets | 2016-06-24 08:52:50 Usage end date: 2016-07-23 | 2016-06-24 08:52:50 Enabled for: Advanced Features. | 2016-06-24 08:52:50 Enabled for: Sierra Chart Historical Data Service. | 2016-06-24 08:52:50 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-06-24 08:52:50 Current selected Data/Trading service: CQG FIX Trading | 2016-06-24 08:52:50 Chart Update Interval: 500 | 2016-06-24 08:52:50 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-06-24 08:52:50 2016-06-24 08:52:50 Local computer time | 2016-06-24 08:52:50 2016-06-24 12:52:50 Local computer time in UTC | 2016-06-24 08:52:50 2016-06-24 08:52:50 Local computer time in SC Time Zone | 2016-06-24 08:52:50 2016-06-24 11:12:49 Server time in UTC | 2016-06-24 08:52:50 Local computer UTC time and Server UTC time difference: 3 seconds. | 2016-06-24 08:52:50 Program path: C:\SierraChart\ | 2016-06-24 08:52:50 Data Files path: C:\Users\Laurent\Google Drive\SierraChart\Data\ | 2016-06-24 08:52:50 OS Version Number: 6.2 | 2016-06-24 08:52:50 Locale Setting: C | 2016-06-24 08:52:50 A request for the latest software update has been made. | 2016-06-24 08:53:22 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2016-06-24 08:53:22 * HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-24 08:53:22 HTTP connection to www.sierrachart.com:80 (60) | Connected. | 2016-06-24 08:53:22 There is no new version available. | 2016-06-24 08:53:24 * HTTP connection to www.sierrachart.com:80 (60) | Closed. No error. | 2016-06-24 08:53:29 HTTP connection to www.sierrachart.com:80 (60) | Shutdown and closed. | 2016-06-24 08:53:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-06-24 08:53:31 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-06-24 08:53:31 socket (61) | Connected. | 2016-06-24 08:53:32 CQG FIX: Sending the Logon message. | 2016-06-24 08:53:32 CQG FIX Trading | Connected to trading server. | 2016-06-24 08:53:32 CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-06-24 08:53:32 CQG WebAPI | Connecting to websocket server. | 2016-06-24 08:53:32 CQG FIX | FCM name: Wedbush | 2016-06-24 08:53:33 CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 208.48.16.35. | 2016-06-24 08:53:33 CQG WebAPI websocket (62) | Connected. | 2016-06-24 08:53:33 CQG WebAPI websocket (62) | Starting SSL 3/2 connection. | 2016-06-24 08:53:33 CQG WebAPI websocket (62) | SSL connection established. | 2016-06-24 08:53:35 CQG WebAPI | Opening websocket. | 2016-06-24 08:53:35 CQG WebAPI | Sending websocket handshake. | 2016-06-24 08:53:35 CQG WebAPI | Received websocket handshake acknowledgment. | 2016-06-24 08:53:35 CQG WebAPI | Web socket state is now open. | 2016-06-24 08:53:35 CQG FIX Trading | Websocket connected. | 2016-06-24 08:53:35 CQG FIX Trading | Sending market data logon message. | 2016-06-24 08:53:35 CQG FIX Trading | Logon successful. Session Token = 4C/NIvZzZxTb+aKoCb0S4jH0taVIvMUNl9v7peKVBEg | 2016-06-24 08:53:36 CQG FIX Trading | Connected to data and trading server. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS6U16. ID: 1 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS6U16. ID: 650470 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS6U16. ID: 1 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS6U16 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS6U16 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS3H17. ID: 2 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS3H17. ID: 650471 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS3H17. ID: 2 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS3H17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS3H17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS6H17. ID: 3 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS6H17. ID: 650472 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS6H17. ID: 3 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS6H17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS6H17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS12H18. ID: 4 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS12H18. ID: 650473 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS12H18. ID: 4 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS12H18 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS12H18 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS12M19. ID: 5 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS12M19. ID: 650474 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS12M19. ID: 5 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS12M19 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS12M19 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS12H20. ID: 6 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS12H20. ID: 650475 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS12H20. ID: 6 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAS12H20 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAS12H20 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL6H17. ID: 7 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL6H17. ID: 650476 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL6H17. ID: 7 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL6H17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL6H17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL6U17. ID: 8 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL6U17. ID: 650477 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL6U17. ID: 8 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL6U17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL6U17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12M17. ID: 9 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12M17. ID: 650478 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12M17. ID: 9 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12M17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL12M17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12U17. ID: 10 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12U17. ID: 650479 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12U17. ID: 10 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12U17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL12U17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12M18. ID: 11 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12M18. ID: 650480 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12M18. ID: 11 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12M18 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL12M18 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12U18. ID: 12 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12U18. ID: 650481 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12U18. ID: 12 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12U18 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAL12U18 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.ZQES1J17. ID: 13 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.ZQES1J17. ID: 650482 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.ZQES1J17. ID: 13 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.ZQES1J17 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.ZQES1J17 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.ZQEQ16. ID: 14 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.ZQEQ16. ID: 650483 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.ZQEQ16. ID: 14 | 2016-06-24 08:53:36 Requesting market depth updates for: F.US.ZQEQ16 if supported. | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.ZQEQ16 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.ZQEV16. ID: 15 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.ZQEV16. ID: 650484 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.ZQEV16. ID: 15 | 2016-06-24 08:53:36 Requesting market depth updates for: F.US.ZQEV16 if supported. | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.ZQEV16 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAN16. ID: 16 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAN16. ID: 650485 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAN16. ID: 16 | 2016-06-24 08:53:36 Requesting market depth updates for: F.US.EDAN16 if supported. | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAN16 is set to download 'Pending'. | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAD12Z19. ID: 17 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAD12Z19. ID: 650486 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAD12Z19. ID: 17 | 2016-06-24 08:53:36 CQG FIX Trading | Using primary service for historical data for F.US.EDAD12Z19 | 2016-06-24 08:53:36 Intraday data recording state for symbol F.US.EDAD12Z19 is set to download 'Pending'. | 2016-06-24 08:53:36 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS6U16 | 2016-06-24 08:53:36 Delaying start of download for F.US.EDAS6U16 | 2016-06-24 08:53:36 Market data subscription status is not known while delaying historical data download for symbol: F.US.ZQEQ16 | 2016-06-24 08:53:36 Delaying start of download for F.US.ZQEQ16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS6U6. Search Symbol: F.US.EDAS6U16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS6U16. Request ID: 650470. Contract ID: 1. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS6U16 | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12Z19. ID: 18 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12Z19. ID: 650487 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12Z19. ID: 18 | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12Z20. ID: 19 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12Z20. ID: 650488 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12Z20. ID: 19 | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAS12H00. ID: 20 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAS12H00. ID: 650489 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAS12H00. ID: 20 | 2016-06-24 08:53:36 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12Z16. ID: 21 | 2016-06-24 08:53:36 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12Z16. ID: 650490 | 2016-06-24 08:53:36 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12Z16. ID: 21 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS3H7. Search Symbol: F.US.EDAS3H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS3H17. Request ID: 650471. Contract ID: 2. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS3H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS6H7. Search Symbol: F.US.EDAS6H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS6H17. Request ID: 650472. Contract ID: 3. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS6H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS12H8. Search Symbol: F.US.EDAS12H18 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS12H18. Request ID: 650473. Contract ID: 4. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS12H18 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS12M9. Search Symbol: F.US.EDAS12M19 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS12M19. Request ID: 650474. Contract ID: 5. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS12M19 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12U8. Search Symbol: F.US.EDAL12U18 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12U18. Request ID: 650481. Contract ID: 6. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL12U18 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.ZQES1J7. Search Symbol: F.US.ZQES1J17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.ZQES1J17. Request ID: 650482. Contract ID: 7. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.ZQES1J17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.ZQEQ6. Search Symbol: F.US.ZQEQ16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.ZQEQ16. Request ID: 650483. Contract ID: 8. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data including full depth for F.US.ZQEQ16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.ZQEV6. Search Symbol: F.US.ZQEV16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.ZQEV16. Request ID: 650484. Contract ID: 9. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data including full depth for F.US.ZQEV16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAN6. Search Symbol: F.US.EDAN16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAN16. Request ID: 650485. Contract ID: 10. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data including full depth for F.US.EDAN16 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAD12Z9. Search Symbol: F.US.EDAD12Z19 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAD12Z19. Request ID: 650486. Contract ID: 11. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAD12Z19 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS12H0. Search Symbol: F.US.EDAS12H20 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS12H20. Request ID: 650475. Contract ID: 12. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAS12H20 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL6H7. Search Symbol: F.US.EDAL6H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL6H17. Request ID: 650476. Contract ID: 13. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL6H17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL6U7. Search Symbol: F.US.EDAL6U17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL6U17. Request ID: 650477. Contract ID: 14. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL6U17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12M7. Search Symbol: F.US.EDAL12M17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12M17. Request ID: 650478. Contract ID: 15. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL12M17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12U7. Search Symbol: F.US.EDAL12U17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12U17. Request ID: 650479. Contract ID: 16. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL12U17 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12M8. Search Symbol: F.US.EDAL12M18 | 2016-06-24 08:53:36 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12M18. Request ID: 650480. Contract ID: 17. | 2016-06-24 08:53:36 CQG FIX Trading | Requesting market data for F.US.EDAL12M18 | 2016-06-24 08:53:36 Market data subscription status is not known while delaying historical data download for symbol: F.US.ZQEQ16 | 2016-06-24 08:53:37 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS6U16 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12Z9. Search Symbol: F.US.EDAL12Z19 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12Z19. Request ID: 650487. Contract ID: 18. | 2016-06-24 08:53:37 CQG FIX Trading | Requesting market data for F.US.EDAL12Z19 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12Z0. Search Symbol: F.US.EDAL12Z20 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12Z20. Request ID: 650488. Contract ID: 19. | 2016-06-24 08:53:37 CQG FIX Trading | Requesting market data for F.US.EDAL12Z20 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for: F.US.EDAS12H0. Search Symbol: F.US.EDAS12H00 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAS12H00. Request ID: 650489. Contract ID: 12. | 2016-06-24 08:53:37 CQG FIX Trading | Requesting market data for F.US.EDAS12H00 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12Z6. Search Symbol: F.US.EDAL12Z16 | 2016-06-24 08:53:37 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12Z16. Request ID: 650490. Contract ID: 20. | 2016-06-24 08:53:37 CQG FIX Trading | Requesting market data for F.US.EDAL12Z16 | 2016-06-24 08:53:37 Opened cached Depth file: C:\Users\Laurent\Google Drive\SierraChart\Data\MarketDepthData\F.US.ZQEQ16.2016-06-24.depth | 2016-06-24 08:53:37 Opened cached Depth file: C:\Users\Laurent\Google Drive\SierraChart\Data\MarketDepthData\F.US.ZQEV16.2016-06-24.depth | 2016-06-24 08:53:37 Opened cached Depth file: C:\Users\Laurent\Google Drive\SierraChart\Data\MarketDepthData\F.US.EDAN16.2016-06-24.depth | 2016-06-24 08:53:37 Delaying start of download for F.US.EDAS6U16 | 2016-06-24 08:53:38 Delaying start of download for F.US.ZQEQ16 | 2016-06-24 08:53:38 Requesting market depth updates for: F.US.EDAS12H20 if supported. | 2016-06-24 08:53:41 CQG FIX Trading | Requesting market data including full depth for F.US.EDAS12H00 | 2016-06-24 08:53:41 Requesting market depth updates for: F.US.EDAS6H17 if supported. | 2016-06-24 08:53:41 CQG FIX Trading | Requesting market data including full depth for F.US.EDAS6H17 | 2016-06-24 08:53:41 HD Request # 19 | Downloading Intraday chart data for F.US.ZQEQ16 to the file F.US.ZQEQ16.scid. Service: cbot | 2016-06-24 08:53:41 HD Request # 19 | Download start Date-Time: 2016-06-24 08:51:12.000 | 2016-06-24 08:53:41 HD Request # 20 | Downloading Intraday chart data for F.US.EDAS6U16 to the file F.US.EDAS6U16.scid. Service: cqg | 2016-06-24 08:53:41 HD Request # 19 | Using server: scdf1.sierracharts.com port 10149 | 2016-06-24 08:53:41 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-06-24 08:53:41 HD Request # 20 | Download start Date-Time: 2016-06-24 08:46:09.000 | 2016-06-24 08:53:41 Socket (63) | Connected. | 2016-06-24 08:53:41 HD Request # 19 | Sending historical data logon request message. | 2016-06-24 08:53:41 HD Request # 20 | Error downloading historical Intraday data for F.US.EDAS6U16. Time and sales data for instrument F.US.EDAS6 (corresponding to ID = 1) is not allowed. | 2016-06-24 08:53:41 HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS6U16 | 2016-06-24 08:53:41 HD Request # 20 | Intraday download COMPLETE for F.US.EDAS6U16. Completion time: 0s. Unique request ID: 18 | 2016-06-24 08:53:41 Removed historical data download ID 18 | 2016-06-24 08:53:41 Real-time Intraday chart data file updates started for F.US.EDAS6U16 | 2016-06-24 08:53:41 Intraday chart data file opened for F.US.EDAS6U16 | 2016-06-24 08:53:41 HD Request # 21 | Downloading Intraday chart data for F.US.EDAS3H17 to the file F.US.EDAS3H17.scid. Service: cqg | 2016-06-24 08:53:41 HD Request # 21 | Download start Date-Time: 2016-06-24 08:51:44.000 | 2016-06-24 08:53:41 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-06-24 08:51:12. Record interval: 1. Symbol: ZQQ16 | 2016-06-24 08:53:42 HD Request # 21 | Error downloading historical Intraday data for F.US.EDAS3H17. Time and sales data for instrument F.US.EDAS3 (corresponding to ID = 2) is not allowed. | 2016-06-24 08:53:42 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS3H17 | 2016-06-24 08:53:42 HD Request # 21 | Intraday download COMPLETE for F.US.EDAS3H17. Completion time: 0s. Unique request ID: 19 | 2016-06-24 08:53:42 Removed historical data download ID 19 | 2016-06-24 08:53:42 Real-time Intraday chart data file updates started for F.US.EDAS3H17 | 2016-06-24 08:53:42 Intraday chart data file opened for F.US.EDAS3H17 | 2016-06-24 08:53:42 HD Request # 22 | Downloading Intraday chart data for F.US.EDAS6H17 to the file F.US.EDAS6H17.scid. Service: cqg | 2016-06-24 08:53:42 HD Request # 22 | Download start Date-Time: 2016-06-24 08:51:40.000 | 2016-06-24 08:53:42 HD Request # 19 | Decompressing data. | 2016-06-24 08:53:42 Socket (63) | Shutdown and closed. | 2016-06-24 08:53:42 The network socket for historical data has been closed. | 2016-06-24 08:53:42 HD Request # 19 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ZQEQ16 | 2016-06-24 08:53:42 HD Request # 19 | Intraday download COMPLETE for F.US.ZQEQ16. Completion time: 2s. Unique request ID: 31 | 2016-06-24 08:53:42 Removed historical data download ID 31 | 2016-06-24 08:53:42 Real-time Intraday chart data file updates started for F.US.ZQEQ16 | 2016-06-24 08:53:42 Intraday chart data file opened for F.US.ZQEQ16 | 2016-06-24 08:53:42 HD Request # 23 | Downloading Intraday chart data for F.US.ZQEV16 to the file F.US.ZQEV16.scid. Service: cbot | 2016-06-24 08:53:42 HD Request # 23 | Download start Date-Time: 2016-06-24 08:51:48.000 | 2016-06-24 08:53:42 HD Request # 23 | Using server: scdf2.sierracharts.com port 10149 | 2016-06-24 08:53:42 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-06-24 08:53:42 HD Request # 22 | Error downloading historical Intraday data for F.US.EDAS6H17. Time and sales data for instrument F.US.EDAS6 (corresponding to ID = 3) is not allowed. | 2016-06-24 08:53:42 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS6H17 | 2016-06-24 08:53:42 HD Request # 22 | Intraday download COMPLETE for F.US.EDAS6H17. Completion time: 1s. Unique request ID: 20 | 2016-06-24 08:53:42 Removed historical data download ID 20 | 2016-06-24 08:53:42 Real-time Intraday chart data file updates started for F.US.EDAS6H17 | 2016-06-24 08:53:42 Intraday chart data file opened for F.US.EDAS6H17 | 2016-06-24 08:53:42 HD Request # 24 | Downloading Intraday chart data for F.US.EDAS12H18 to the file F.US.EDAS12H18.scid. Service: cqg | 2016-06-24 08:53:42 HD Request # 24 | Download start Date-Time: 2016-06-24 08:49:53.000 | 2016-06-24 08:53:42 Socket (64) | Connected. | 2016-06-24 08:53:43 HD Request # 23 | Sending historical data logon request message. | 2016-06-24 08:53:43 HD Request # 24 | Error downloading historical Intraday data for F.US.EDAS12H18. Time and sales data for instrument F.US.EDAS12 (corresponding to ID = 4) is not allowed. | 2016-06-24 08:53:43 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS12H18 | 2016-06-24 08:53:43 HD Request # 24 | Intraday download COMPLETE for F.US.EDAS12H18. Completion time: 0s. Unique request ID: 21 | 2016-06-24 08:53:43 Removed historical data download ID 21 | 2016-06-24 08:53:43 Real-time Intraday chart data file updates started for F.US.EDAS12H18 | 2016-06-24 08:53:43 Intraday chart data file opened for F.US.EDAS12H18 | 2016-06-24 08:53:43 HD Request # 25 | Downloading Intraday chart data for F.US.EDAS12M19 to the file F.US.EDAS12M19.scid. Service: cqg | 2016-06-24 08:53:43 HD Request # 25 | Download start Date-Time: 2016-06-24 08:45:18.000 | 2016-06-24 08:53:43 HD Request # 25 | Error downloading historical Intraday data for F.US.EDAS12M19. Time and sales data for instrument F.US.EDAS12 (corresponding to ID = 5) is not allowed. | 2016-06-24 08:53:43 HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS12M19 | 2016-06-24 08:53:43 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-06-24 08:51:48. Record interval: 1. Symbol: ZQV16 | 2016-06-24 08:53:43 HD Request # 25 | Intraday download COMPLETE for F.US.EDAS12M19. Completion time: 1s. Unique request ID: 22 | 2016-06-24 08:53:43 Removed historical data download ID 22 | 2016-06-24 08:53:43 Real-time Intraday chart data file updates started for F.US.EDAS12M19 | 2016-06-24 08:53:43 Intraday chart data file opened for F.US.EDAS12M19 | 2016-06-24 08:53:43 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:43 Delaying start of download for F.US.EDAS12H20 | 2016-06-24 08:53:43 HD Request # 23 | Decompressing data. | 2016-06-24 08:53:43 Socket (64) | Shutdown and closed. | 2016-06-24 08:53:43 The network socket for historical data has been closed. | 2016-06-24 08:53:43 HD Request # 23 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ZQEV16 | 2016-06-24 08:53:43 HD Request # 23 | Intraday download COMPLETE for F.US.ZQEV16. Completion time: 1s. Unique request ID: 32 | 2016-06-24 08:53:43 Removed historical data download ID 32 | 2016-06-24 08:53:43 Real-time Intraday chart data file updates started for F.US.ZQEV16 | 2016-06-24 08:53:43 Intraday chart data file opened for F.US.ZQEV16 | 2016-06-24 08:53:43 HD Request # 26 | Downloading Intraday chart data for F.US.EDAN16 to the file F.US.EDAN16.scid. Service: cme | 2016-06-24 08:53:43 HD Request # 26 | Download start Date-Time: 2016-06-24 08:52:24.000 | 2016-06-24 08:53:43 HD Request # 26 | Using server: scdf1.sierracharts.com port 10149 | 2016-06-24 08:53:43 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-06-24 08:53:43 Socket (65) | Connected. | 2016-06-24 08:53:43 HD Request # 26 | Sending historical data logon request message. | 2016-06-24 08:53:43 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-06-24 08:52:24. Record interval: 1. Symbol: GEN16 | 2016-06-24 08:53:44 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:44 HD Request # 26 | Decompressing data. | 2016-06-24 08:53:44 Socket (65) | Shutdown and closed. | 2016-06-24 08:53:44 The network socket for historical data has been closed. | 2016-06-24 08:53:44 HD Request # 26 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAN16 | 2016-06-24 08:53:44 HD Request # 26 | Intraday download COMPLETE for F.US.EDAN16. Completion time: 0s. Unique request ID: 33 | 2016-06-24 08:53:44 Removed historical data download ID 33 | 2016-06-24 08:53:44 Real-time Intraday chart data file updates started for F.US.EDAN16 | 2016-06-24 08:53:44 Intraday chart data file opened for F.US.EDAN16 | 2016-06-24 08:53:44 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:45 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:46 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12U16 | 2016-06-24 08:53:47 F.US.EDAL12U16 #9 | Reloading chart. | 2016-06-24 08:53:47 CQG FIX Trading | Starting real-time market data updates for: F.US.EDAL12U16. ID: 22 | 2016-06-24 08:53:47 CQG FIX Trading | Sending symbol resolution request for F.US.EDAL12U16. ID: 650496 | 2016-06-24 08:53:47 CQG FIX Trading | Requesting security definition data for: F.US.EDAL12U16. ID: 22 | 2016-06-24 08:53:47 CQG FIX Trading | Using primary service for historical data for F.US.EDAL12U16 | 2016-06-24 08:53:47 Intraday data recording state for symbol F.US.EDAL12U16 is set to download 'Pending'. | 2016-06-24 08:53:47 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:47 CQG FIX Trading | Received symbol resolution report for: F.US.EDAL12U6. Search Symbol: F.US.EDAL12U16 | 2016-06-24 08:53:47 CQG FIX Trading | Received symbol resolution report for symbol F.US.EDAL12U16. Request ID: 650496. Contract ID: 21. | 2016-06-24 08:53:47 CQG FIX Trading | Requesting market data for F.US.EDAL12U16 | 2016-06-24 08:53:47 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:48 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:49 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:50 Unsubscribed from market depth data for F.US.EDAS12H20 | 2016-06-24 08:53:51 CQG FIX Trading | Requesting market data for F.US.EDAS12H00 | 2016-06-24 08:53:51 Requesting market depth updates for: F.US.EDAL12U16 if supported. | 2016-06-24 08:53:51 CQG FIX Trading | Requesting market data including full depth for F.US.EDAL12U16 | 2016-06-24 08:53:51 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:51 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:52 Market data subscription status is not known while delaying historical data download for symbol: F.US.EDAS12H20 | 2016-06-24 08:53:53 HD Request # 27 | Downloading Intraday chart data for F.US.EDAS12H20 to the file F.US.EDAS12H20.scid. Service: cqg | 2016-06-24 08:53:53 HD Request # 27 | Download start Date-Time: 2015-12-21 07:53:52.000 | 2016-06-24 08:53:53 HD Request # 27 | Error downloading historical Intraday data for F.US.EDAS12H20. Time and sales data for instrument F.US.EDAS12 (corresponding to ID = 12) is not allowed. | 2016-06-24 08:53:53 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAS12H20 | 2016-06-24 08:53:53 HD Request # 27 | Intraday download COMPLETE for F.US.EDAS12H20. Completion time: 1s. Unique request ID: 23 | 2016-06-24 08:53:53 Removed historical data download ID 23 | 2016-06-24 08:53:53 Real-time Intraday chart data file updates started for F.US.EDAS12H20 | 2016-06-24 08:53:53 Intraday chart data file opened for F.US.EDAS12H20 | 2016-06-24 08:53:53 HD Request # 28 | Downloading Intraday chart data for F.US.EDAL6H17 to the file F.US.EDAL6H17.scid. Service: cqg | 2016-06-24 08:53:53 HD Request # 28 | Download start Date-Time: 2016-06-24 08:35:48.000 | 2016-06-24 08:53:53 HD Request # 28 | Error downloading historical Intraday data for F.US.EDAL6H17. Time and sales data for instrument F.US.EDAL6 (corresponding to ID = 13) is not allowed. | 2016-06-24 08:53:53 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL6H17 | 2016-06-24 08:53:53 HD Request # 28 | Intraday download COMPLETE for F.US.EDAL6H17. Completion time: 0s. Unique request ID: 24 | 2016-06-24 08:53:53 Removed historical data download ID 24 | 2016-06-24 08:53:53 Real-time Intraday chart data file updates started for F.US.EDAL6H17 | 2016-06-24 08:53:53 Intraday chart data file opened for F.US.EDAL6H17 | 2016-06-24 08:53:53 HD Request # 29 | Downloading Intraday chart data for F.US.EDAL6U17 to the file F.US.EDAL6U17.scid. Service: cqg | 2016-06-24 08:53:53 HD Request # 29 | Download start Date-Time: 2016-06-24 06:54:51.000 | 2016-06-24 08:53:53 HD Request # 29 | Error downloading historical Intraday data for F.US.EDAL6U17. Time and sales data for instrument F.US.EDAL6 (corresponding to ID = 14) is not allowed. | 2016-06-24 08:53:53 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL6U17 | 2016-06-24 08:53:53 HD Request # 29 | Intraday download COMPLETE for F.US.EDAL6U17. Completion time: 0s. Unique request ID: 25 | 2016-06-24 08:53:53 Removed historical data download ID 25 | 2016-06-24 08:53:53 Real-time Intraday chart data file updates started for F.US.EDAL6U17 | 2016-06-24 08:53:53 Intraday chart data file opened for F.US.EDAL6U17 | 2016-06-24 08:53:53 HD Request # 30 | Downloading Intraday chart data for F.US.EDAL12M17 to the file F.US.EDAL12M17.scid. Service: cqg | 2016-06-24 08:53:53 HD Request # 30 | Download start Date-Time: 2016-06-24 08:42:46.000 | 2016-06-24 08:53:53 HD Request # 30 | Error downloading historical Intraday data for F.US.EDAL12M17. Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 15) is not allowed. | 2016-06-24 08:53:53 HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL12M17 | 2016-06-24 08:53:53 HD Request # 30 | Intraday download COMPLETE for F.US.EDAL12M17. Completion time: 0s. Unique request ID: 26 | 2016-06-24 08:53:53 Removed historical data download ID 26 | 2016-06-24 08:53:53 Real-time Intraday chart data file updates started for F.US.EDAL12M17 | 2016-06-24 08:53:53 Intraday chart data file opened for F.US.EDAL12M17 | 2016-06-24 08:53:53 HD Request # 31 | Downloading Intraday chart data for F.US.EDAL12U17 to the file F.US.EDAL12U17.scid. Service: cqg | 2016-06-24 08:53:53 HD Request # 31 | Download start Date-Time: 2016-06-24 08:48:49.000 | 2016-06-24 08:53:53 HD Request # 31 | Error downloading historical Intraday data for F.US.EDAL12U17. Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 16) is not allowed. | 2016-06-24 08:53:54 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL12U17 | 2016-06-24 08:53:54 HD Request # 31 | Intraday download COMPLETE for F.US.EDAL12U17. Completion time: 0s. Unique request ID: 27 | 2016-06-24 08:53:54 Removed historical data download ID 27 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.EDAL12U17 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.EDAL12U17 | 2016-06-24 08:53:54 HD Request # 32 | Downloading Intraday chart data for F.US.EDAL12M18 to the file F.US.EDAL12M18.scid. Service: cqg | 2016-06-24 08:53:54 HD Request # 32 | Download start Date-Time: 2016-06-24 08:42:46.000 | 2016-06-24 08:53:54 HD Request # 32 | Error downloading historical Intraday data for F.US.EDAL12M18. Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 17) is not allowed. | 2016-06-24 08:53:54 HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL12M18 | 2016-06-24 08:53:54 HD Request # 32 | Intraday download COMPLETE for F.US.EDAL12M18. Completion time: 0s. Unique request ID: 28 | 2016-06-24 08:53:54 Removed historical data download ID 28 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.EDAL12M18 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.EDAL12M18 | 2016-06-24 08:53:54 HD Request # 33 | Downloading Intraday chart data for F.US.EDAL12U18 to the file F.US.EDAL12U18.scid. Service: cqg | 2016-06-24 08:53:54 HD Request # 33 | Download start Date-Time: 2016-06-24 08:28:19.000 | 2016-06-24 08:53:54 Opened cached Intraday file: C:\Users\Laurent\Google Drive\SierraChart\Data\F.US.ZQEQ16.scid | 2016-06-24 08:53:54 Opened cached Intraday file: C:\Users\Laurent\Google Drive\SierraChart\Data\F.US.ZQEV16.scid | 2016-06-24 08:53:54 HD Request # 33 | Error downloading historical Intraday data for F.US.EDAL12U18. Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 6) is not allowed. | 2016-06-24 08:53:54 HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL12U18 | 2016-06-24 08:53:54 HD Request # 33 | Intraday download COMPLETE for F.US.EDAL12U18. Completion time: 0s. Unique request ID: 29 | 2016-06-24 08:53:54 Removed historical data download ID 29 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.EDAL12U18 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.EDAL12U18 | 2016-06-24 08:53:54 HD Request # 34 | Downloading Intraday chart data for F.US.ZQES1J17 to the file F.US.ZQES1J17.scid. Service: cqg | 2016-06-24 08:53:54 HD Request # 34 | Download start Date-Time: 2016-06-24 08:37:02.000 | 2016-06-24 08:53:54 HD Request # 34 | Error downloading historical Intraday data for F.US.ZQES1J17. Time and sales data for instrument F.US.ZQES1 (corresponding to ID = 7) is not allowed. | 2016-06-24 08:53:54 HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.ZQES1J17 | 2016-06-24 08:53:54 HD Request # 34 | Intraday download COMPLETE for F.US.ZQES1J17. Completion time: 0s. Unique request ID: 30 | 2016-06-24 08:53:54 Removed historical data download ID 30 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.ZQES1J17 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.ZQES1J17 | 2016-06-24 08:53:54 HD Request # 35 | Downloading Intraday chart data for F.US.EDAD12Z19 to the file F.US.EDAD12Z19.scid. Service: cqg | 2016-06-24 08:53:54 HD Request # 35 | Download start Date-Time: 2016-06-24 01:41:52.000 | 2016-06-24 08:53:54 HD Request # 35 | Error downloading historical Intraday data for F.US.EDAD12Z19. Time and sales data for instrument F.US.EDAD12 (corresponding to ID = 11) is not allowed. | 2016-06-24 08:53:54 HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAD12Z19 | 2016-06-24 08:53:54 HD Request # 35 | Intraday download COMPLETE for F.US.EDAD12Z19. Completion time: 0s. Unique request ID: 34 | 2016-06-24 08:53:54 Removed historical data download ID 34 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.EDAD12Z19 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.EDAD12Z19 | 2016-06-24 08:53:54 HD Request # 36 | Downloading Intraday chart data for F.US.EDAL12U16 to the file F.US.EDAL12U16.scid. Service: cqg | 2016-06-24 08:53:54 HD Request # 36 | Download start Date-Time: 2016-06-24 00:29:46.000 | 2016-06-24 08:53:54 HD Request # 36 | Error downloading historical Intraday data for F.US.EDAL12U16. Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 21) is not allowed. | 2016-06-24 08:53:54 HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EDAL12U16 | 2016-06-24 08:53:54 HD Request # 36 | Intraday download COMPLETE for F.US.EDAL12U16. Completion time: 0s. Unique request ID: 35 | 2016-06-24 08:53:54 Removed historical data download ID 35 | 2016-06-24 08:53:54 Real-time Intraday chart data file updates started for F.US.EDAL12U16 | 2016-06-24 08:53:54 Intraday chart data file opened for F.US.EDAL12U16 | 2016-06-24 08:53:54 CQG FIX Trading | Using primary service for historical data for F.US.EDAS12H20 | 2016-06-24 08:54:00 F.US.EDAS12H20 #9 | Reloading chart. | 2016-06-24 08:54:00 F.US.EDAS12H20 #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\Laurent\Google Drive\SierraChart\Data\F.US.EDAS12H20.scid | 2016-06-24 08:54:00 Unsubscribed from market depth data for F.US.EDAL12U16 | 2016-06-24 08:54:01 CQG FIX Trading | Requesting market data for F.US.EDAL12U16 | 2016-06-24 08:54:01 Requesting market depth updates for: F.US.EDAS12H20 if supported. | 2016-06-24 08:54:01 CQG FIX Trading | Requesting market data including full depth for F.US.EDAS12H00 | 2016-06-24 08:54:01 |
[2016-06-24 18:20:48] |
We see what the problem is. Your CQG account is not authorized for historical price data: Time and sales data for instrument F.US.EDAL12 (corresponding to ID = 21) is not allowed. | 2016-06-24 08:53:54
Have your broker add that authorization to your account. When that is done reconnect, to the data feed: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-24 18:24:09
