Date/Time: Tue, 14 May 2024 14:53:08 +0000
Anyone seeing or not seeing a problem with DAX futures?
View Count: 871
[2016-06-14 07:24:01] |
Leo33 - Posts: 73 |
My DAX-201606-DTB-EUR-25 feed is basically stopped but my IB DAX CFD is moving normally. I don't know if it's actual/real or a feed or exchange thing. Anyone got an idea? |
[2016-06-14 07:27:20] |
Leo33 - Posts: 73 |
[the volume is extremely slow] I've checked I don't think it's rollover? |
[2016-06-14 07:27:39] |
Futurestrader77 - Posts: 126 |
Dear Support Team, I am missing levels in the market depth for FGBL and FESX on Eurex with the SC Data Feed. Please see attached a snapshot for FGBL. Could you please take a look into it? Thanks! Best regards. |
[2016-06-14 07:27:58] |
We are checking on this.
[2016-06-14 07:35:45] |
Leo33 - Posts: 73 |
My FESX has ground to a halt also volume and Best Bid n Offers BUND too ES-201606-GLOBEX is/seems ok Date Time Of Last Edit: 2016-06-14 07:36:37
[2016-06-14 07:37:21] |
This is clearly a Barchart data problem. We are working on it.
[2016-06-14 07:44:59] |
There is clearly a Barchart data problem. We are going patch in a different data feed, but that may take us up to 30 minutes.
[2016-06-14 08:22:20] |
The EUREX data feed is now working. We apologize for the issue. It was a Barchart server data problem. They have been notified about it. We are using an alternate data feed at this time. We will make it clear to them, that they need to do a much better job and this is quite serious because this is the second time in recent months this has happened. There is going to be some incomplete data today for the EUREX due to the data problem. Follow the instructions here to re-download the data where there is incomplete data in the chart: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart If there is any further problem, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-14 08:33:57] |
I am assuming that you are using the CQG Data Feed now? Would it be possible to use it for Eurex permantly? It clearly works better and in adition it provides 20 levels of market depth each side. |
[2016-06-14 09:30:10] |
We will keep it on one server until Barchart releases EUREX over Open Feed. We cannot use it on both servers because it has no redundancy. Also the Barchart feed is also a CQG feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-14 09:32:10
