Date/Time: Sun, 19 May 2024 11:20:03 +0000
Symbol format for weekly BankNifty options recently introduced by NSEINDIA
View Count: 1731
[2016-06-08 21:32:38] |
User857142 - Posts: 82 |
Hi - This is wrt Global Data Feed India (NSEINDIA exchange) Normally, the monthly option has following format i.e. BANKNIFTY-NS-OPT-201606-C-18000 means 6th month of 2016 with a usual last Thursday (in this case 30th June 2016) of the month as expiry! Irrespective of that date, the format has only only year and month details i.e. 201606 What will be the symbol format for weekly BankNifty options contract recently introduced by NSEINDIA which is ending on lets say 9th June 2016? I have asked Global data feed to give me symbol format for weekly options contract for BANKNIFTY introduced by NSEINDIA. They asked me to contact you. Kindly help. Date Time Of Last Edit: 2016-06-08 21:33:31
[2016-06-08 22:03:11] |
Yes they did contact us about this. We apologize for the delay. We just need to go over this carefully and have not had a chance to do it yet. We will do it today.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 11:07:38
[2016-06-09 11:07:02] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/GlobalDataFeeds_India.php#UsingOptionSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-09 11:10:00] |
Actually, as we are reviewing this more carefully now, we see that you do understand the options format but you want to know how to set the expiration date for the weekly options. Obviously we do not know that and only Global Data Feeds would know the particular text string that needs to be used in the year and month field. We assume it is just going to be something like 20160609. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 11:11:01
[2016-06-09 14:17:23] |
This is the reply which I have got from GFDL: "Sir, Sierra Chart is charting platform & our data is compatible with them..symbol format for sierra chart is designed by them" "we have also asked them for exact symbol format with example but we have not yet received answer from them" "we have also asked them in reply that "It will be nice if you can give some examples please ?" In short, I have been told that the symbol format will be provided by Sierra Chart team! Btw - I tried using different combos with 20160609 as suffix, but none of them worked! Please help! |
[2016-06-09 14:46:27] |
Also, in addition to this why these future symbols given in symbol list MCDOWELL-N-NS-FUT-201606 and BAJAJ-AUTO-NS-FUT-201606 dont work? I mean they dont open/update/download - no charts! Date Time Of Last Edit: 2016-06-09 14:47:36
[2016-06-09 17:09:49] |
Each of the parts of the complete symbol string between the hyphens (-), are just sent as is to the corresponding fields in the FIX message. Therefore, regarding what particular format to use for each of the parts depends upon what the requirements of the FIX server is. Global Data Feeds can be consulted for further information about this. So you need to ask Global Data Feeds what is the text string for the Maturity Month Year field for a weekly option. We do not know. They really should know this. Regarding MCDOWELL-N-NS-FUT-201606 and BAJAJ-AUTO-NS-FUT-201606
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 17:10:12
[2016-06-09 20:49:50] |
For the generated log, I have used "send for analysis". Kindly confirm and help. As a small note there, I have also given URL for current post/support request as reference. Date Time Of Last Edit: 2016-06-09 20:50:22
[2016-06-10 06:19:43] |
Symbols with this kind of format with an additional hyphen will be supported in the next release coming out later today: MCDOWELL-N-NS-FUT-201606 and BAJAJ-AUTO-NS-FUT-201606
[2016-06-27 20:27:23] |
Wrt last post, still MCDOWELL-N-NS-FUT-201606 ( format with an additional hyphen) is not getting updated with the latest current version!
[2016-06-27 21:27:56] |
We are looking into this.
[2016-06-27 21:32:20] |
We have verified in the current version, 1434, that the symbol MCDOWELL-N-NS-FUT-201606 is properly processed and sent to Global Data Feeds. Therefore, if there still is a problem provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-28 04:10:39] |
For the generated log, I have used "send for analysis". Kindly confirm and help. As a small note there, I have also given URL for current post/support request as reference. |
[2016-06-28 04:27:46] |
That Message Log does not give us what we require. Reconnect to the data feed following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect After that use Send for Analysis again and let us know when that is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-08-05 07:35:49] |
Hi Can you please today. I have sent it you via "send for analysis". As a small note there, I have also given URL for current post/support request as reference. Kindly confirm and help. |
[2016-08-06 11:05:50] |
This is the relevant message from the Message Log: HD Request # 28 | Error downloading historical Intraday data for MCDOWELL-N-NS-FUT-201608. Invalid scrip combination Symbol MCDOWELLN Exchange NS | 2016-08-05 10:20:58 We know why this happens and it will be resolved in 1452 coming out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-08-06 11:05:59
