Date/Time: Tue, 29 Sep 2026 08:03:31 +0000
Rithmic data
View Count: 1002
[2016-05-23 18:06:31]
User573721 - Posts: 26
Hello, today I experienced problem with Rithmic data. I'm not able to receive any data and Sierra Chart is in state "connecting". I have Sierra Chart package 5. Thanks for quick feedback. A.Kocisova
Message log:
Software version: 1415 | 2016-05-23 12:35:29
Uses New Spreadsheets | 2016-05-23 12:35:29
Enabled for: Advanced Features. | 2016-05-23 12:35:29
Enabled for: Advanced Features 2. | 2016-05-23 12:35:29
Enabled for: Sierra Chart Historical Data Service. | 2016-05-23 12:35:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-23 12:35:29
Current selected Data/Trading service: Rithmic Trading | 2016-05-23 12:35:29
Chart Update Interval: 500 | 2016-05-23 12:35:29
Data/Trade Service Settings automatically set. | 2016-05-23 12:35:29
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-05-23 12:35:29
2016-05-23 19:35:33 Local computer time | 2016-05-23 12:35:29
2016-05-23 17:35:33 Local computer time in UTC | 2016-05-23 12:35:29
2016-05-23 12:35:33 Local computer time in SC Time Zone | 2016-05-23 12:35:29
2016-05-23 17:35:33 Server time in UTC | 2016-05-23 12:35:29
Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-05-23 12:35:29
Program path: C:\SierraChart\ | 2016-05-23 12:35:29
Data Files path: C:\SierraChart\Data\ | 2016-05-23 12:35:29
OS Version Number: 6.1 | 2016-05-23 12:35:29
Locale Setting: C | 2016-05-23 12:35:29
Checking for new symbol settings for rim | 2016-05-23 12:35:29
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-23 12:35:29
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-23 12:35:29
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-23 12:35:29
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-23 12:35:29
Symbol settings are up-to-date for rim | 2016-05-23 12:35:29
Files to Open on Start up | Opening file: FIMS.cht | 2016-05-23 12:35:36
Files to Open on Start up | Opening file: Goblin2.cht | 2016-05-23 12:35:36
Files to Open on Start up | File does not exist: C:\SierraChart\Data\Sek_Goblin.cht | 2016-05-23 12:35:36
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-23 12:35:36
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-23 12:35:36
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-23 12:35:36
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-23 12:35:36
Chart #12 has tagged chart #7 for full recalculation. Chartbook: Goblin2.cht | 2016-05-23 12:35:36
Intraday data recording state for symbol YMM6-CBOT is set to download 'Pending'. | 2016-05-23 12:36:20
HD Request # 2 | Downloading Intraday chart data for YMM6-CBOT to the file YMM6-CBOT.scid. Service: rim | 2016-05-23 12:36:20
HD Request # 2 | Download start Date-Time: 2016-05-20 11:18:13.000 | 2016-05-23 12:36:20
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2016-05-23 12:36:20
Intraday data recording state for symbol ESM6-CME is set to download 'Pending'. | 2016-05-23 12:36:20
Intraday data recording state for symbol NQM6-CME is set to download 'Pending'. | 2016-05-23 12:36:20
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-23 12:36:20
Intraday data recording state for symbol EMDM6-CME is set to download 'Pending'. | 2016-05-23 12:36:20
Socket (4) | Connected. | 2016-05-23 12:36:20
HD Request # 2 | Sending historical data logon request message. | 2016-05-23 12:36:20
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-23 12:36:20
NQM6-CME 1 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: Goblin2.cht | 2016-05-23 12:36:20
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-05-20 11:18:13. Record interval: 0. Symbol: YMM6-CBOT | 2016-05-23 12:36:20
Socket (4) | Shutdown and closed. | 2016-05-23 12:36:20
The network socket for historical data has been closed. | 2016-05-23 12:36:20
HD Request # 2 | Historical data for YMM6-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-23 12:36:20
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMM6-CBOT | 2016-05-23 12:36:20
HD Request # 2 | Intraday download COMPLETE for YMM6-CBOT. Completion time: 2s. Unique request ID: 1 | 2016-05-23 12:36:20
Removed historical data download ID 1 | 2016-05-23 12:36:20
HD Request # 3 | Downloading Intraday chart data for ESM6-CME to the file ESM6-CME.scid. Service: rim | 2016-05-23 12:36:20
HD Request # 3 | Download start Date-Time: 2016-05-20 11:18:17.000 | 2016-05-23 12:36:20
HD Request # 3 | Using server: ds5.sierracharts.com port 10149 | 2016-05-23 12:36:20
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-23 12:36:20
Rithmic Trading | Port for executable: 51656 | 2016-05-23 12:36:20
Listening socket (872), port 51656 | Closed. | 2016-05-23 12:36:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:36:20
Socket (5) | Connected. | 2016-05-23 12:36:23
HD Request # 3 | Sending historical data logon request message. | 2016-05-23 12:36:23
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-05-20 11:18:17. Record interval: 0. Symbol: ESM6-CME | 2016-05-23 12:36:23
HD Request # 3 | Historical data for ESM6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-23 12:36:23
Socket (5) | Shutdown and closed. | 2016-05-23 12:36:23
The network socket for historical data has been closed. | 2016-05-23 12:36:23
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM6-CME | 2016-05-23 12:36:23
HD Request # 3 | Intraday download COMPLETE for ESM6-CME. Completion time: 1s. Unique request ID: 2 | 2016-05-23 12:36:23
Removed historical data download ID 2 | 2016-05-23 12:36:23
HD Request # 4 | Downloading Intraday chart data for NQM6-CME to the file NQM6-CME.scid. Service: rim | 2016-05-23 12:36:23
HD Request # 4 | Download start Date-Time: 2016-05-20 11:18:16.000 | 2016-05-23 12:36:23
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2016-05-23 12:36:23
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-23 12:36:23
Socket (6) | Connected. | 2016-05-23 12:36:23
HD Request # 4 | Sending historical data logon request message. | 2016-05-23 12:36:23
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-05-20 11:18:16. Record interval: 0. Symbol: NQM6-CME | 2016-05-23 12:36:24
HD Request # 4 | Historical data for NQM6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-23 12:36:24
Socket (6) | Shutdown and closed. | 2016-05-23 12:36:24
The network socket for historical data has been closed. | 2016-05-23 12:36:24
HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM6-CME | 2016-05-23 12:36:24
HD Request # 4 | Intraday download COMPLETE for NQM6-CME. Completion time: 1s. Unique request ID: 3 | 2016-05-23 12:36:24
Removed historical data download ID 3 | 2016-05-23 12:36:24
HD Request # 5 | Downloading Intraday chart data for EMDM6-CME to the file EMDM6-CME.scid. Service: rim | 2016-05-23 12:36:24
HD Request # 5 | Download start Date-Time: 2016-05-20 11:17:18.000 | 2016-05-23 12:36:24
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2016-05-23 12:36:24
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-23 12:36:24
Socket (7) | Connected. | 2016-05-23 12:36:24
HD Request # 5 | Sending historical data logon request message. | 2016-05-23 12:36:24
Chart #12 has tagged chart #7 for full recalculation. Chartbook: Goblin2.cht | 2016-05-23 12:36:24
Chart #12 has tagged chart #11 for full recalculation. Chartbook: FIMS.cht | 2016-05-23 12:36:24
NQM6-CME 1 Sec #7 | Performing a full recalculation because it has been tagged. Chartbook: Goblin2.cht | 2016-05-23 12:36:24
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-05-20 11:17:18. Record interval: 0. Symbol: EMDM6-CME | 2016-05-23 12:36:24
Socket (7) | Shutdown and closed. | 2016-05-23 12:36:24
HD Request # 5 | Historical data for EMDM6-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-23 12:36:24
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EMDM6-CME | 2016-05-23 12:36:24
HD Request # 5 | Intraday download COMPLETE for EMDM6-CME. Completion time: 2s. Unique request ID: 4 | 2016-05-23 12:36:24
Removed historical data download ID 4 | 2016-05-23 12:36:24
HD Request # 6 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-23 12:36:24
HD Request # 6 | Download start Date-Time: 2016-05-23 11:21:21.000 | 2016-05-23 12:36:24
HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2016-05-23 12:36:24
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-23 12:36:24
NQM6-CME 1 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: FIMS.cht | 2016-05-23 12:36:26
Socket (8) | Connected. | 2016-05-23 12:36:26
HD Request # 6 | Sending historical data logon request message. | 2016-05-23 12:36:26
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2016-05-23 11:21:21. Record interval: 0. Symbol: TICK-NYSE | 2016-05-23 12:36:26
HD Request # 6 | Decompressing data. | 2016-05-23 12:36:26
HD Request # 6 | Receiving Intraday data for TICK-NYSE starting at 2016-05-23 11:21:21 | 2016-05-23 12:36:26
HD Request # 6 | Timestamp of first Intraday data file record written: 2016-05-23 11:21:22 | 2016-05-23 12:36:26
Socket (8) | Shutdown and closed. | 2016-05-23 12:36:26
The network socket for historical data has been closed. | 2016-05-23 12:36:26
HD Request # 6 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-23 12:36:26
HD Request # 6 | Received 4256 records from 2016-05-23 11:21:21 to 2016-05-23 12:36:28 (75.1 minutes) and wrote 4255 records for TICK-NYSE | 2016-05-23 12:36:26
HD Request # 6 | Intraday download COMPLETE for TICK-NYSE. Completion time: 2s. Unique request ID: 5 | 2016-05-23 12:36:26
Removed historical data download ID 5 | 2016-05-23 12:36:26
Chart #19 has tagged chart #18 for full recalculation. Chartbook: FIMS.cht | 2016-05-23 12:36:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51656 | 2016-05-23 12:36:26
Socket (9) | Connected. | 2016-05-23 12:36:26
Rithmic Trading | Connected to server. | 2016-05-23 12:36:26
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:36:26
Chart #10 has tagged chart #9 for full recalculation. Chartbook: Goblin2.cht | 2016-05-23 12:36:26
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:36:26
Rithmic Trading | Sending logon request message. | 2016-05-23 12:36:26
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:36:28
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:36:28
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:36:28
YMM6-CBOT 5 Sec #18 | Performing a full recalculation because it has been tagged. Chartbook: FIMS.cht | 2016-05-23 12:36:28
NQM6-CME 5 Sec #9 | Performing a full recalculation because it has been tagged. Chartbook: Goblin2.cht | 2016-05-23 12:36:28
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:36:58
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:37:21
Rithmic Trading | Received logon response. | 2016-05-23 12:37:21
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:37:21
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:37:21
Rithmic Trading | Logon error received from server | 2016-05-23 12:37:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:37:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:37:21
Socket (9) | Shutdown and closed. | 2016-05-23 12:37:21
Rithmic Trading | Disconnected. | 2016-05-23 12:37:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:37:21
Rithmic Trading | Port for executable: 51675 | 2016-05-23 12:37:23
Listening socket (860), port 51675 | Closed. | 2016-05-23 12:37:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:37:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51675 | 2016-05-23 12:37:25
Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:37:26
Socket (10) | Shutdown and closed. | 2016-05-23 12:37:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:37:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:37:26
Rithmic Trading | Disconnected. | 2016-05-23 12:37:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:37:26
Rithmic Trading | Port for executable: 51678 | 2016-05-23 12:37:28
Listening socket (812), port 51678 | Closed. | 2016-05-23 12:37:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:37:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51678 | 2016-05-23 12:37:30
Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:37:31
Socket (11) | Shutdown and closed. | 2016-05-23 12:37:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:37:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:37:31
Rithmic Trading | Disconnected. | 2016-05-23 12:37:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:37:31
Rithmic Trading | Port for executable: 51681 | 2016-05-23 12:37:33
Listening socket (860), port 51681 | Closed. | 2016-05-23 12:37:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:37:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51681 | 2016-05-23 12:37:35
Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:37:36
Socket (13) | Shutdown and closed. | 2016-05-23 12:37:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:37:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:37:36
Rithmic Trading | Disconnected. | 2016-05-23 12:37:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:37:36
Rithmic Trading | Port for executable: 51683 | 2016-05-23 12:37:38
Listening socket (560), port 51683 | Closed. | 2016-05-23 12:37:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:37:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51683 | 2016-05-23 12:37:40
Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:37:41
Socket (14) | Shutdown and closed. | 2016-05-23 12:37:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:37:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:37:41
Rithmic Trading | Disconnected. | 2016-05-23 12:37:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:37:41
Rithmic Trading | Port for executable: 51688 | 2016-05-23 12:37:43
Listening socket (576), port 51688 | Closed. | 2016-05-23 12:37:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:37:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51688 | 2016-05-23 12:37:45
Socket (15) | Connected. | 2016-05-23 12:37:45
Rithmic Trading | Connected to server. | 2016-05-23 12:37:45
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:37:45
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:37:45
Rithmic Trading | Sending logon request message. | 2016-05-23 12:37:45
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:37:45
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:37:45
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:37:45
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:38:14
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:38:37
Rithmic Trading | Received logon response. | 2016-05-23 12:38:37
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:38:37
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:38:37
Rithmic Trading | Logon error received from server | 2016-05-23 12:38:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:38:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:38:37
Socket (15) | Shutdown and closed. | 2016-05-23 12:38:37
Rithmic Trading | Disconnected. | 2016-05-23 12:38:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:38:37
Rithmic Trading | Port for executable: 51704 | 2016-05-23 12:38:39
Listening socket (560), port 51704 | Closed. | 2016-05-23 12:38:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:38:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51704 | 2016-05-23 12:38:41
Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:38:42
Socket (16) | Shutdown and closed. | 2016-05-23 12:38:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:38:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:38:42
Rithmic Trading | Disconnected. | 2016-05-23 12:38:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:38:42
Rithmic Trading | Port for executable: 51707 | 2016-05-23 12:38:44
Listening socket (576), port 51707 | Closed. | 2016-05-23 12:38:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:38:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51707 | 2016-05-23 12:38:46
Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:38:47
Socket (17) | Shutdown and closed. | 2016-05-23 12:38:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:38:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:38:47
Rithmic Trading | Disconnected. | 2016-05-23 12:38:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:38:47
Rithmic Trading | Port for executable: 51709 | 2016-05-23 12:38:49
Listening socket (788), port 51709 | Closed. | 2016-05-23 12:38:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:38:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51709 | 2016-05-23 12:38:51
Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:38:52
Socket (18) | Shutdown and closed. | 2016-05-23 12:38:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:38:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:38:52
Rithmic Trading | Disconnected. | 2016-05-23 12:38:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:38:52
Rithmic Trading | Port for executable: 51711 | 2016-05-23 12:38:54
Listening socket (720), port 51711 | Closed. | 2016-05-23 12:38:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:38:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51711 | 2016-05-23 12:38:56
Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:38:58
Socket (19) | Shutdown and closed. | 2016-05-23 12:38:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:38:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:38:58
Rithmic Trading | Disconnected. | 2016-05-23 12:38:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:38:58
Rithmic Trading | Port for executable: 51713 | 2016-05-23 12:39:00
Listening socket (560), port 51713 | Closed. | 2016-05-23 12:39:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:39:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51713 | 2016-05-23 12:39:02
Socket (20) | Connected. | 2016-05-23 12:39:02
Rithmic Trading | Connected to server. | 2016-05-23 12:39:02
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:39:02
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:39:02
Rithmic Trading | Sending logon request message. | 2016-05-23 12:39:02
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:39:02
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:39:02
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:39:02
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:39:31
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:39:53
Rithmic Trading | Received logon response. | 2016-05-23 12:39:53
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:39:53
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:39:53
Rithmic Trading | Logon error received from server | 2016-05-23 12:39:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:39:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:39:53
Socket (20) | Shutdown and closed. | 2016-05-23 12:39:53
Rithmic Trading | Disconnected. | 2016-05-23 12:39:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:39:53
Rithmic Trading | Port for executable: 51733 | 2016-05-23 12:39:55
Listening socket (788), port 51733 | Closed. | 2016-05-23 12:39:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:39:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51733 | 2016-05-23 12:39:57
Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:39:58
Socket (22) | Shutdown and closed. | 2016-05-23 12:39:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:39:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:39:58
Rithmic Trading | Disconnected. | 2016-05-23 12:39:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:39:58
Rithmic Trading | Port for executable: 51735 | 2016-05-23 12:40:00
Listening socket (560), port 51735 | Closed. | 2016-05-23 12:40:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:40:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51735 | 2016-05-23 12:40:03
Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:40:04
Socket (23) | Shutdown and closed. | 2016-05-23 12:40:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:40:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:40:04
Rithmic Trading | Disconnected. | 2016-05-23 12:40:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:40:04
Rithmic Trading | Port for executable: 51737 | 2016-05-23 12:40:06
Listening socket (788), port 51737 | Closed. | 2016-05-23 12:40:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:40:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51737 | 2016-05-23 12:40:08
Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:40:09
Socket (24) | Shutdown and closed. | 2016-05-23 12:40:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:40:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:40:09
Rithmic Trading | Disconnected. | 2016-05-23 12:40:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:40:09
Rithmic Trading | Port for executable: 51739 | 2016-05-23 12:40:11
Listening socket (560), port 51739 | Closed. | 2016-05-23 12:40:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:40:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51739 | 2016-05-23 12:40:13
Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:40:14
Socket (25) | Shutdown and closed. | 2016-05-23 12:40:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:40:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:40:14
Rithmic Trading | Disconnected. | 2016-05-23 12:40:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:40:14
Rithmic Trading | Port for executable: 51741 | 2016-05-23 12:40:16
Listening socket (720), port 51741 | Closed. | 2016-05-23 12:40:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:40:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51741 | 2016-05-23 12:40:18
Socket (26) | Connected. | 2016-05-23 12:40:18
Rithmic Trading | Connected to server. | 2016-05-23 12:40:18
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:40:18
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:40:18
Rithmic Trading | Sending logon request message. | 2016-05-23 12:40:18
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:40:18
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:40:18
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:40:18
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:40:48
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:41:10
Rithmic Trading | Received logon response. | 2016-05-23 12:41:10
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:41:10
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:41:10
Rithmic Trading | Logon error received from server | 2016-05-23 12:41:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:41:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:41:10
Socket (26) | Shutdown and closed. | 2016-05-23 12:41:10
Rithmic Trading | Disconnected. | 2016-05-23 12:41:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:41:10
Rithmic Trading | Port for executable: 51775 | 2016-05-23 12:41:12
Listening socket (788), port 51775 | Closed. | 2016-05-23 12:41:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:41:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51775 | 2016-05-23 12:41:14
Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:41:15
Socket (27) | Shutdown and closed. | 2016-05-23 12:41:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:41:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:41:15
Rithmic Trading | Disconnected. | 2016-05-23 12:41:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:41:15
Rithmic Trading | Port for executable: 51777 | 2016-05-23 12:41:17
Listening socket (720), port 51777 | Closed. | 2016-05-23 12:41:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:41:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51777 | 2016-05-23 12:41:19
Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:41:20
Socket (28) | Shutdown and closed. | 2016-05-23 12:41:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:41:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:41:20
Rithmic Trading | Disconnected. | 2016-05-23 12:41:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:41:20
Rithmic Trading | Port for executable: 51779 | 2016-05-23 12:41:22
Listening socket (812), port 51779 | Closed. | 2016-05-23 12:41:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:41:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51779 | 2016-05-23 12:41:24
Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:41:25
Socket (29) | Shutdown and closed. | 2016-05-23 12:41:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:41:25
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:41:25
Rithmic Trading | Disconnected. | 2016-05-23 12:41:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:41:25
Rithmic Trading | Port for executable: 51781 | 2016-05-23 12:41:27
Listening socket (576), port 51781 | Closed. | 2016-05-23 12:41:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:41:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51781 | 2016-05-23 12:41:29
Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:41:30
Socket (30) | Shutdown and closed. | 2016-05-23 12:41:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:41:30
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:41:30
Rithmic Trading | Disconnected. | 2016-05-23 12:41:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:41:30
Rithmic Trading | Port for executable: 51784 | 2016-05-23 12:41:32
Listening socket (788), port 51784 | Closed. | 2016-05-23 12:41:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:41:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51784 | 2016-05-23 12:41:34
Socket (32) | Connected. | 2016-05-23 12:41:34
Rithmic Trading | Connected to server. | 2016-05-23 12:41:34
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:41:34
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:41:34
Rithmic Trading | Sending logon request message. | 2016-05-23 12:41:34
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:41:34
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:41:34
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:41:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:42:04
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:42:26
Rithmic Trading | Received logon response. | 2016-05-23 12:42:26
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:42:26
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:42:26
Rithmic Trading | Logon error received from server | 2016-05-23 12:42:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:42:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:42:26
Socket (32) | Shutdown and closed. | 2016-05-23 12:42:26
Rithmic Trading | Disconnected. | 2016-05-23 12:42:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:42:26
Rithmic Trading | Port for executable: 51801 | 2016-05-23 12:42:28
Listening socket (884), port 51801 | Closed. | 2016-05-23 12:42:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:42:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51801 | 2016-05-23 12:42:30
Socket (33) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:42:31
Socket (33) | Shutdown and closed. | 2016-05-23 12:42:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:42:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:42:31
Rithmic Trading | Disconnected. | 2016-05-23 12:42:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:42:31
Rithmic Trading | Port for executable: 51803 | 2016-05-23 12:42:33
Listening socket (788), port 51803 | Closed. | 2016-05-23 12:42:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:42:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51803 | 2016-05-23 12:42:35
Socket (34) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:42:36
Socket (34) | Shutdown and closed. | 2016-05-23 12:42:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:42:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:42:36
Rithmic Trading | Disconnected. | 2016-05-23 12:42:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:42:36
Rithmic Trading | Port for executable: 51805 | 2016-05-23 12:42:38
Listening socket (884), port 51805 | Closed. | 2016-05-23 12:42:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:42:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51805 | 2016-05-23 12:42:40
Socket (35) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:42:41
Socket (35) | Shutdown and closed. | 2016-05-23 12:42:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:42:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:42:41
Rithmic Trading | Disconnected. | 2016-05-23 12:42:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:42:41
Rithmic Trading | Port for executable: 51807 | 2016-05-23 12:42:43
Listening socket (812), port 51807 | Closed. | 2016-05-23 12:42:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:42:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51807 | 2016-05-23 12:42:45
Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:42:47
Socket (36) | Shutdown and closed. | 2016-05-23 12:42:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:42:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:42:47
Rithmic Trading | Disconnected. | 2016-05-23 12:42:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:42:47
Rithmic Trading | Port for executable: 51809 | 2016-05-23 12:42:49
Listening socket (720), port 51809 | Closed. | 2016-05-23 12:42:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:42:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51809 | 2016-05-23 12:42:51
Socket (37) | Connected. | 2016-05-23 12:42:51
Rithmic Trading | Connected to server. | 2016-05-23 12:42:51
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:42:51
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:42:51
Rithmic Trading | Sending logon request message. | 2016-05-23 12:42:51
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:42:51
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:42:51
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:42:51
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:43:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:43:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:43:22
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:43:43
Rithmic Trading | Received logon response. | 2016-05-23 12:43:43
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:43:43
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:43:43
Rithmic Trading | Logon error received from server | 2016-05-23 12:43:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:43:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:43:43
Socket (37) | Shutdown and closed. | 2016-05-23 12:43:43
Rithmic Trading | Disconnected. | 2016-05-23 12:43:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:43:43
Rithmic Trading | Port for executable: 51837 | 2016-05-23 12:43:45
Listening socket (884), port 51837 | Closed. | 2016-05-23 12:43:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:43:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51837 | 2016-05-23 12:43:47
Socket (39) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:43:48
Socket (39) | Shutdown and closed. | 2016-05-23 12:43:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:43:48
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:43:48
Rithmic Trading | Disconnected. | 2016-05-23 12:43:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:43:48
Rithmic Trading | Port for executable: 51839 | 2016-05-23 12:43:50
Listening socket (720), port 51839 | Closed. | 2016-05-23 12:43:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:43:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51839 | 2016-05-23 12:43:51
Socket (40) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:43:53
Socket (40) | Shutdown and closed. | 2016-05-23 12:43:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:43:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:43:53
Rithmic Trading | Disconnected. | 2016-05-23 12:43:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:43:53
Rithmic Trading | Port for executable: 51841 | 2016-05-23 12:43:55
Listening socket (812), port 51841 | Closed. | 2016-05-23 12:43:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:43:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51841 | 2016-05-23 12:43:57
Socket (41) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:43:58
Socket (41) | Shutdown and closed. | 2016-05-23 12:43:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:43:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:43:58
Rithmic Trading | Disconnected. | 2016-05-23 12:43:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:43:58
Rithmic Trading | Port for executable: 51844 | 2016-05-23 12:44:00
Listening socket (788), port 51844 | Closed. | 2016-05-23 12:44:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:44:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51844 | 2016-05-23 12:44:02
Socket (42) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:44:03
Socket (42) | Shutdown and closed. | 2016-05-23 12:44:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:44:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:44:03
Rithmic Trading | Disconnected. | 2016-05-23 12:44:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:44:03
Rithmic Trading | Port for executable: 51846 | 2016-05-23 12:44:05
Listening socket (884), port 51846 | Closed. | 2016-05-23 12:44:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:44:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51846 | 2016-05-23 12:44:07
Socket (43) | Connected. | 2016-05-23 12:44:07
Rithmic Trading | Connected to server. | 2016-05-23 12:44:07
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:44:07
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:44:07
Rithmic Trading | Sending logon request message. | 2016-05-23 12:44:07
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:44:07
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:44:07
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:44:07
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:44:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:44:38
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:44:38
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:44:59
Rithmic Trading | Received logon response. | 2016-05-23 12:44:59
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:44:59
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:44:59
Rithmic Trading | Logon error received from server | 2016-05-23 12:44:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:44:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:44:59
Socket (43) | Shutdown and closed. | 2016-05-23 12:44:59
Rithmic Trading | Disconnected. | 2016-05-23 12:44:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:44:59
Rithmic Trading | Port for executable: 51864 | 2016-05-23 12:45:01
Listening socket (812), port 51864 | Closed. | 2016-05-23 12:45:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:45:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51864 | 2016-05-23 12:45:03
Socket (44) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:45:04
Socket (44) | Shutdown and closed. | 2016-05-23 12:45:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:45:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:45:04
Rithmic Trading | Disconnected. | 2016-05-23 12:45:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:45:04
Rithmic Trading | Port for executable: 51866 | 2016-05-23 12:45:06
Listening socket (884), port 51866 | Closed. | 2016-05-23 12:45:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:45:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51866 | 2016-05-23 12:45:08
Socket (45) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:45:09
Socket (45) | Shutdown and closed. | 2016-05-23 12:45:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:45:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:45:09
Rithmic Trading | Disconnected. | 2016-05-23 12:45:09
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:45:09
Rithmic Trading | Port for executable: 51869 | 2016-05-23 12:45:11
Listening socket (572), port 51869 | Closed. | 2016-05-23 12:45:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:45:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51869 | 2016-05-23 12:45:13
Socket (46) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:45:14
Socket (46) | Shutdown and closed. | 2016-05-23 12:45:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:45:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:45:14
Rithmic Trading | Disconnected. | 2016-05-23 12:45:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:45:14
Rithmic Trading | Port for executable: 51872 | 2016-05-23 12:45:16
Listening socket (576), port 51872 | Closed. | 2016-05-23 12:45:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:45:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51872 | 2016-05-23 12:45:18
Socket (47) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:45:19
Socket (47) | Shutdown and closed. | 2016-05-23 12:45:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:45:19
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:45:19
Rithmic Trading | Disconnected. | 2016-05-23 12:45:19
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:45:19
Rithmic Trading | Port for executable: 51874 | 2016-05-23 12:45:21
Listening socket (572), port 51874 | Closed. | 2016-05-23 12:45:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:45:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51874 | 2016-05-23 12:45:23
Socket (48) | Connected. | 2016-05-23 12:45:23
Rithmic Trading | Connected to server. | 2016-05-23 12:45:23
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:45:23
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:45:23
Rithmic Trading | Sending logon request message. | 2016-05-23 12:45:23
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:45:23
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:45:23
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:45:23
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:45:53
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:45:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:45:55
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:46:16
Rithmic Trading | Received logon response. | 2016-05-23 12:46:16
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:46:16
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:46:16
Rithmic Trading | Logon error received from server | 2016-05-23 12:46:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:46:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:46:16
Socket (48) | Shutdown and closed. | 2016-05-23 12:46:16
Rithmic Trading | Disconnected. | 2016-05-23 12:46:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:46:16
Rithmic Trading | Port for executable: 51894 | 2016-05-23 12:46:18
Listening socket (884), port 51894 | Closed. | 2016-05-23 12:46:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:46:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51894 | 2016-05-23 12:46:20
Socket (50) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:46:21
Socket (50) | Shutdown and closed. | 2016-05-23 12:46:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:46:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:46:21
Rithmic Trading | Disconnected. | 2016-05-23 12:46:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:46:21
Rithmic Trading | Port for executable: 51896 | 2016-05-23 12:46:23
Listening socket (572), port 51896 | Closed. | 2016-05-23 12:46:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:46:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51896 | 2016-05-23 12:46:25
Socket (51) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:46:26
Socket (51) | Shutdown and closed. | 2016-05-23 12:46:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:46:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:46:26
Rithmic Trading | Disconnected. | 2016-05-23 12:46:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:46:26
Rithmic Trading | Port for executable: 51898 | 2016-05-23 12:46:28
Listening socket (576), port 51898 | Closed. | 2016-05-23 12:46:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:46:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51898 | 2016-05-23 12:46:30
Socket (52) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:46:31
Socket (52) | Shutdown and closed. | 2016-05-23 12:46:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:46:31
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:46:31
Rithmic Trading | Disconnected. | 2016-05-23 12:46:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:46:31
Rithmic Trading | Port for executable: 51900 | 2016-05-23 12:46:33
Listening socket (560), port 51900 | Closed. | 2016-05-23 12:46:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:46:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51900 | 2016-05-23 12:46:35
Socket (53) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:46:36
Socket (53) | Shutdown and closed. | 2016-05-23 12:46:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:46:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:46:36
Rithmic Trading | Disconnected. | 2016-05-23 12:46:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:46:36
Rithmic Trading | Port for executable: 51902 | 2016-05-23 12:46:38
Listening socket (884), port 51902 | Closed. | 2016-05-23 12:46:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:46:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51902 | 2016-05-23 12:46:40
Socket (54) | Connected. | 2016-05-23 12:46:40
Rithmic Trading | Connected to server. | 2016-05-23 12:46:40
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:46:40
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:46:40
Rithmic Trading | Sending logon request message. | 2016-05-23 12:46:40
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:46:40
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:46:40
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:46:40
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:47:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:47:11
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:47:12
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:47:32
Rithmic Trading | Received logon response. | 2016-05-23 12:47:32
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:47:32
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:47:32
Rithmic Trading | Logon error received from server | 2016-05-23 12:47:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:47:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:47:32
Socket (54) | Shutdown and closed. | 2016-05-23 12:47:32
Rithmic Trading | Disconnected. | 2016-05-23 12:47:32
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:47:32
Rithmic Trading | Port for executable: 51930 | 2016-05-23 12:47:34
Listening socket (812), port 51930 | Closed. | 2016-05-23 12:47:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:47:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51930 | 2016-05-23 12:47:36
Socket (56) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:47:37
Socket (56) | Shutdown and closed. | 2016-05-23 12:47:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:47:37
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:47:37
Rithmic Trading | Disconnected. | 2016-05-23 12:47:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:47:37
Rithmic Trading | Port for executable: 51932 | 2016-05-23 12:47:39
Listening socket (572), port 51932 | Closed. | 2016-05-23 12:47:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:47:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51932 | 2016-05-23 12:47:41
Socket (57) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:47:42
Socket (57) | Shutdown and closed. | 2016-05-23 12:47:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:47:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:47:42
Rithmic Trading | Disconnected. | 2016-05-23 12:47:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:47:42
Rithmic Trading | Port for executable: 51945 | 2016-05-23 12:47:44
Listening socket (884), port 51945 | Closed. | 2016-05-23 12:47:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:47:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51945 | 2016-05-23 12:47:46
Socket (58) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:47:47
Socket (58) | Shutdown and closed. | 2016-05-23 12:47:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:47:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:47:47
Rithmic Trading | Disconnected. | 2016-05-23 12:47:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:47:47
Rithmic Trading | Port for executable: 51948 | 2016-05-23 12:47:49
Listening socket (572), port 51948 | Closed. | 2016-05-23 12:47:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:47:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51948 | 2016-05-23 12:47:51
Socket (59) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:47:52
Socket (59) | Shutdown and closed. | 2016-05-23 12:47:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:47:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:47:52
Rithmic Trading | Disconnected. | 2016-05-23 12:47:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:47:52
Rithmic Trading | Port for executable: 51950 | 2016-05-23 12:47:55
Listening socket (720), port 51950 | Closed. | 2016-05-23 12:47:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:47:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51950 | 2016-05-23 12:47:57
Socket (60) | Connected. | 2016-05-23 12:47:57
Rithmic Trading | Connected to server. | 2016-05-23 12:47:57
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:47:57
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:47:57
Rithmic Trading | Sending logon request message. | 2016-05-23 12:47:57
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:47:57
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:47:57
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:47:57
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:48:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:48:28
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:48:28
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:48:49
Rithmic Trading | Received logon response. | 2016-05-23 12:48:49
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:48:49
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:48:49
Rithmic Trading | Logon error received from server | 2016-05-23 12:48:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:48:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:48:49
Socket (60) | Shutdown and closed. | 2016-05-23 12:48:49
Rithmic Trading | Disconnected. | 2016-05-23 12:48:49
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:48:49
Rithmic Trading | Port for executable: 51967 | 2016-05-23 12:48:51
Listening socket (884), port 51967 | Closed. | 2016-05-23 12:48:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:48:51
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51967 | 2016-05-23 12:48:53
Socket (61) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:48:54
Socket (61) | Shutdown and closed. | 2016-05-23 12:48:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:48:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:48:54
Rithmic Trading | Disconnected. | 2016-05-23 12:48:54
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:48:54
Rithmic Trading | Port for executable: 51969 | 2016-05-23 12:48:56
Listening socket (720), port 51969 | Closed. | 2016-05-23 12:48:56
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:48:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51969 | 2016-05-23 12:48:58
Socket (62) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:48:59
Socket (62) | Shutdown and closed. | 2016-05-23 12:48:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:48:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:48:59
Rithmic Trading | Disconnected. | 2016-05-23 12:48:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:48:59
Rithmic Trading | Port for executable: 51971 | 2016-05-23 12:49:01
Listening socket (884), port 51971 | Closed. | 2016-05-23 12:49:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:49:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51971 | 2016-05-23 12:49:03
Socket (63) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:49:04
Socket (63) | Shutdown and closed. | 2016-05-23 12:49:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:49:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:49:04
Rithmic Trading | Disconnected. | 2016-05-23 12:49:04
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:49:04
Rithmic Trading | Port for executable: 51973 | 2016-05-23 12:49:06
Listening socket (644), port 51973 | Closed. | 2016-05-23 12:49:06
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:49:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51973 | 2016-05-23 12:49:08
Socket (64) | Error received in OnConnect while connecting. Windows error code 10061: Nedalo sa vytvori žiadne spojenie, pretože cie¾ový poèítaè ho aktívne odmietol. | 2016-05-23 12:49:09
Socket (64) | Shutdown and closed. | 2016-05-23 12:49:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:49:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:49:09
Rithmic Trading | Disconnected. | 2016-05-23 12:49:09
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:49:09
Successfully processed Sierra Chart account data. | 2016-05-23 12:49:33
Rithmic Trading | Port for executable: 52011 | 2016-05-23 12:51:09
Listening socket (996), port 52011 | Closed. | 2016-05-23 12:51:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:51:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52011 | 2016-05-23 12:51:11
Socket (67) | Connected. | 2016-05-23 12:51:11
Rithmic Trading | Connected to server. | 2016-05-23 12:51:11
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:51:11
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:51:11
Rithmic Trading | Sending logon request message. | 2016-05-23 12:51:11
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:51:11
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:51:11
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:51:11
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:51:41
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:51:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:51:43
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:52:03
Rithmic Trading | Received logon response. | 2016-05-23 12:52:03
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:52:03
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:52:03
Rithmic Trading | Logon error received from server | 2016-05-23 12:52:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:52:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:52:03
Socket (67) | Shutdown and closed. | 2016-05-23 12:52:03
Rithmic Trading | Disconnected. | 2016-05-23 12:52:03
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:52:03
Rithmic Trading | Port for executable: 52056 | 2016-05-23 12:54:03
Listening socket (996), port 52056 | Closed. | 2016-05-23 12:54:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:54:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52056 | 2016-05-23 12:54:05
Socket (70) | Connected. | 2016-05-23 12:54:05
Rithmic Trading | Connected to server. | 2016-05-23 12:54:05
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:54:05
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:54:05
Rithmic Trading | Sending logon request message. | 2016-05-23 12:54:05
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:54:05
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:54:05
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:54:05
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:54:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:54:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:54:37
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:54:58
Rithmic Trading | Received logon response. | 2016-05-23 12:54:58
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:54:58
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:54:58
Rithmic Trading | Logon error received from server | 2016-05-23 12:54:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:54:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:54:58
Socket (70) | Shutdown and closed. | 2016-05-23 12:54:58
Rithmic Trading | Disconnected. | 2016-05-23 12:54:58
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:54:58
Rithmic Trading | Port for executable: 52107 | 2016-05-23 12:56:58
Listening socket (812), port 52107 | Closed. | 2016-05-23 12:56:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:56:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52107 | 2016-05-23 12:57:00
Socket (72) | Connected. | 2016-05-23 12:57:00
Rithmic Trading | Connected to server. | 2016-05-23 12:57:00
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:57:00
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:57:00
Rithmic Trading | Sending logon request message. | 2016-05-23 12:57:00
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:57:00
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:57:00
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:57:00
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 12:57:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 12:57:32
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 12:57:32
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 12:57:51
Rithmic Trading | Received logon response. | 2016-05-23 12:57:51
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 12:57:51
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 12:57:51
Rithmic Trading | Logon error received from server | 2016-05-23 12:57:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 12:57:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 12:57:51
Socket (72) | Shutdown and closed. | 2016-05-23 12:57:51
Rithmic Trading | Disconnected. | 2016-05-23 12:57:51
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 12:57:51
Rithmic Trading | Port for executable: 52133 | 2016-05-23 12:59:52
Listening socket (572), port 52133 | Closed. | 2016-05-23 12:59:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 12:59:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52133 | 2016-05-23 12:59:54
Socket (75) | Connected. | 2016-05-23 12:59:54
Rithmic Trading | Connected to server. | 2016-05-23 12:59:54
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 12:59:54
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 12:59:54
Rithmic Trading | Sending logon request message. | 2016-05-23 12:59:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 12:59:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 12:59:54
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 12:59:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 13:00:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 13:00:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 13:00:25
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 13:00:46
Rithmic Trading | Received logon response. | 2016-05-23 13:00:46
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 13:00:46
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 13:00:46
Rithmic Trading | Logon error received from server | 2016-05-23 13:00:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 13:00:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 13:00:46
Socket (75) | Shutdown and closed. | 2016-05-23 13:00:46
Rithmic Trading | Disconnected. | 2016-05-23 13:00:46
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 13:00:46
The above has been sent to support. | 2016-05-23 13:01:55 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-23 13:01:55
HTTP connection to www.sierrachart.com:80 (77) | Connected. | 2016-05-23 13:01:56
Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2016-05-23 13:01:57
HTTP connection to www.sierrachart.com:80 (77) | Closed. No error. | 2016-05-23 13:02:02
HTTP connection to www.sierrachart.com:80 (77) | Shutdown and closed. | 2016-05-23 13:02:02
Rithmic Trading | Port for executable: 52157 | 2016-05-23 13:02:46
Listening socket (996), port 52157 | Closed. | 2016-05-23 13:02:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 13:02:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52157 | 2016-05-23 13:02:48
Socket (78) | Connected. | 2016-05-23 13:02:48
Rithmic Trading | Connected to server. | 2016-05-23 13:02:48
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 13:02:48
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 13:02:48
Rithmic Trading | Sending logon request message. | 2016-05-23 13:02:48
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 13:02:48
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 13:02:48
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 13:02:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2016-05-23 13:03:18
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-05-23 13:03:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-05-23 13:03:20
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2016-05-23 13:03:40
Rithmic Trading | Received logon response. | 2016-05-23 13:03:40
Rithmic Trading | Server Name: DTC Bridge. | 2016-05-23 13:03:40
Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-05-23 13:03:40
Rithmic Trading | Logon error received from server | 2016-05-23 13:03:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-05-23 13:03:40
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-05-23 13:03:40
Socket (78) | Shutdown and closed. | 2016-05-23 13:03:40
Rithmic Trading | Disconnected. | 2016-05-23 13:03:40
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-05-23 13:03:40
Rithmic Trading | Port for executable: 52197 | 2016-05-23 13:05:40
Listening socket (1048), port 52197 | Closed. | 2016-05-23 13:05:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-05-23 13:05:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52197 | 2016-05-23 13:05:42
Socket (81) | Connected. | 2016-05-23 13:05:42
Rithmic Trading | Connected to server. | 2016-05-23 13:05:42
Rithmic Trading | Sending Encoding Request to server | 2016-05-23 13:05:42
Rithmic Trading | Setting DTC Encoding to Binary | 2016-05-23 13:05:42
Rithmic Trading | Sending logon request message. | 2016-05-23 13:05:42
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-05-23 13:05:42
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-05-23 13:05:42
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-05-23 13:05:42
[2016-05-23 18:29:44]
This problem goes directly to the fact of why we do not support these API components which Rithmic uses.
We strongly advise you to contact your broker have them move you over to CQG, from Rithmic.
The above Message Log indicates a very long time to connect to Rithmic and some unexpected behavior from the Rithmic API which Sierra Chart may or may not be handling properly. We do not know. Clearly there is some kind of connectivity issue though. The problem is that we cannot know how to handle this properly because there is not consistent and standardized behavior with the connection. We simply do not have direct control over this.
Once again, we recommend you contact your broker and have them move you off Rithmic and to CQG. Here are the CQG setup instructions:
http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SetupInstructions
While this gets a bit technical, our policy regarding API components that Rithmic is stated here:
Https://www.sierrachart.com/index.php?l=helpdetails76.html
The CQG symbols are different compared to Rithmic, so you will need to change the symbols of the charts:
http://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html
Date Time Of Last Edit: 2016-05-23 18:32:28
[2016-05-23 18:40:39]
User573721 - Posts: 26
We contacted our broker to verify that account is valid and there is no problem with login or something similar. They connect under our account to rithmic data without any problem. Based on this we think that problem is on local PC but we are unable to identify what is wrong. We tried to disable all security options like antivirus or firewall but without success.
[2016-05-23 18:47:04]
There definitely is some connectivity problem. Could be caused by a firewall or the ISP or some other connectivity problem between your location and the server.
What specifically the connection problem is, is not known because the Rithmic API does not provide those details.
Connecting to CQG is a lot simpler because it uses a single connection that Sierra Chart directly makes.
So you can either try to figure this out and wait to see if it clears or try using CQG. We do not think you will have any trouble with the connection to CQG.
