Date/Time: Sun, 05 May 2024 13:05:32 +0000
Silver in IB problem
View Count: 1651
[2013-07-11 13:54:50] |
mayerrs - Posts: 70 |
hi, i´d like to ask what is going on with SI-201309-NYMEX. i am not able to download data and i can see silver is working normaly in TWS. thx |
[2013-07-11 16:55:28] |
Sierra Chart - Max - Posts: 5605 |
Use the following symbol: SI-201309-NYMEX-USD For more information, please see: Silver Futures Symbol Change at Interactive Brokers effective TODAY (07/10/2013) Sierra Chart Support |
[2013-07-12 11:54:20] |
it did not help.
[2013-07-12 12:38:41] |
You need to use this symbol: SIU3-FUT-NYMEX-USD Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-12 13:05:23] |
it is working but why is this problem only in SI. i have other markets and only in SI i need to use this format?!
[2013-08-02 13:31:27] |
hi, so there is a problem in SI. i ususaly have another format in sierra for IB. SI-201309-NYMEX. as we said i am trying SIU3-FUT-NYMEX-USD. But, now i can se the position line is not displayed. this SIU3-FUT-NYMEX-USD format is unusual for me under IB. can you help?
[2013-08-02 21:21:05] |
We need to do some testing on this and get back to you.
[2013-08-05 02:02:47] |
We have tested this and we have successfully used this symbol: SI-######-NYMEX-USD-5000 You will find this now listed in File >> Find Symbol after restarting Sierra Chart. To get the correct trade positions displayed, please update to the latest revision of 1004 by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-05 02:40:10
