Date/Time: Thu, 02 May 2024 10:39:09 +0000
Time & Sales Total Size Depth.
View Count: 1490
[2016-05-19 12:26:22] |
User341584 - Posts: 44 |
What speed does this study work on? I can't find a chart speed which matches the speed of this study? Thanks in advance. |
[2016-05-19 16:45:30] |
We do not clearly understand the question. At each chart column it represents a market depth update at the best bid and ask. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-19 16:45:45
[2018-06-01 19:11:03] |
chart_warrior - Posts: 96 |
Is it possible to have this study update based on a different timeframe from what the default/live is? I have a study that calculates a ratio between total bid and ask depth. Obviously this changes every second but I want to see what the depth was say at the end of a 1 minute bar. This would be helpful for historical study. I have a setup that depends on this and if I knew what the depth ration was at some time in the past, even if it's just few days, I could study this without having to sit in front of the PC. |
[2018-06-03 08:26:31] |
Refer to this page here: Study/Price Overlay Study: Using the Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-03 08:26:44
[2018-06-11 17:57:38] |
Thanks, this works kind of. The problem is that it's not showing me a bar with wicks so I don't know what the high/low was. If you look at the attached GIF image you will see that ratio is moving but not leaving a trace at the top like a normal candle stick so if I go back in time I don't know what the high/low was. Is there any way to change it? |
2018-06-11_12-33-41.gif / V - Attached On 2018-06-11 17:57:30 UTC - Size: 2.56 MB - 290 views |
