Date/Time: Tue, 29 Sep 2026 08:49:44 +0000
Tick-Nasdaq,Tick-Nyse lags
View Count: 1398
| [2016-05-09 15:47:50] |
| User447007 - Posts: 44 |
Hi, I use IB for data feed, but nor Tick-Nasdaq, nor Tick-nyse shows tha data value what IB TWS shows for Tick-Nasd, and Tick-Nyse. I use ninja and ensign too where the tick data is exactly the same like in IB TWS. What could cause the different ( in sierra the ticks are lagging, and don't show the the same tick value later..) I would like to use tick in sierra too, please help. |
| [2016-05-09 17:44:38] |
These particular symbols are Sierra Chart Market Statistics: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-09 17:44:47
| [2016-05-09 17:45:54] |
If you want to use the Interactive Brokers symbols, then follow the Symbol Format documented here: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-09 18:04:10] |
What I use from IB is market stat, and I got from your "FIND Symbol" for IB on your software. I got live data for that two symbol, but they lags and differ from IB's one: TICK-NYSE TICK-NASDAQ The link what you sent about IB doesn't show Market Stat. Couldn't I use the symbols what I found on your "find symbol" section for IB? Please check out that two symbol with IB, or tell me what should I use them instead of, as your IB link doesn't detail market stat. |
