Date/Time: Sat, 18 May 2024 20:20:18 +0000
Top Step Trader - Using Sierra Charts and data for the combine
View Count: 1830
[2016-05-04 23:16:29] |
Jason - Posts: 17 |
Hello I have an Infinity Futures account where I get my data and Sierra Charts. How do these work with the Top Step Trader combine? Thanks |
[2016-05-05 05:30:30] |
To use Top Step Trader requires that you have your own direct Sierra Chart account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html A discount is available when using Top Step Trader. You will need to use the CTS T4 trading platform service: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-28 21:04:30
[2016-06-28 18:48:02] |
Jason - Posts: 17 |
When using Sierra Charts with Top Step Trader, and not able to use Infinity Futures with it, is there a trading DOM to execute positions?
[2016-06-29 03:03:46] |
Sierra Chart does support TransAct/Infinity. You just need to follow the instructions here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Here is the documentation for the Trading DOM: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#TradeDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
