Date/Time: Sun, 05 May 2024 21:30:33 +0000
fontsize
View Count: 1424
[2013-07-09 16:27:53] |
TGuth1 - Posts: 6 |
the chart values running horizontally across the top...is there a way to make the font for that bigger and also the font for the numbers for the price retracement tool |
[2013-07-09 16:49:02] |
Sierra Chart - Max - Posts: 5605 |
You will need to update the Chart Text Font under Graphics Settings: https://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html The font size for a Chart Drawing Tool can be set with Global Settings >> Tool Settings >> Global Chart Drawing Font. Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartDrawingText Sierra Chart Support |
