Date/Time: Sun, 28 Apr 2024 09:09:00 +0000
IB TWS 952.2 API Settings: Component Exchange Separator
View Count: 6404
[2016-04-17 08:03:42] |
Lesmond - Posts: 21 |
This seems to be a relatively new setting and it looks like it is related to the confusing stock symbol format implemented by IB several months ago: http://i.imgur.com/6qpRMVK.png Here is the link to API Release Notes: https://www.interactivebrokers.com/en/index.php?f=7239 Are we supposed to enter the "slash" in that box (as shown in the screenshot above) or leave it blank? Once there is a clear answer please update IB Setup Instructions page: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#SetupInstructions |
[2016-04-17 21:43:00] |
Documentation has been updated. This is correct: Are we supposed to enter the "slash" in that box (as shown in the screenshot above) or leave it blank? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-25 21:41:42] |
TraderD - Posts: 56 |
I use IB Gateway...should I add the / to the Component Exch. Separator field as well, or is this just for TWS? I trade futures and haven't had any issues without it, but just want to make sure. |
[2017-11-25 21:45:52] |
Yes you will need to do that for sure. But it is not relevant for futures but you should do it anyway just in case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-25 22:23:47] |
Ok, thanks for your quick reply.
