Date/Time: Wed, 01 May 2024 18:21:04 +0000
Bug with Parallel Lines Save Config
View Count: 659
[2016-03-06 15:21:34] |
User37537 - Posts: 78 |
Hi support, I am having issues with saving Parallel Lines configs. I created a Parallel Lines drawing, and under Options I set the 'Extend forward' and 'Mark Anchors' settings. I then saved it as TC1 for the tool. When I use the config to make another Parallel Lines drawing, the Options I set were not saved. The colors and line style were saved, but the options are always reset. If I click on 'Load TC1' from within the Parallel Lines Properties window, it also confirms that the options were not saved. |
[2016-03-06 20:18:38] |
We are checking on this.
[2016-03-06 21:44:32] |
Al SC Developer - Posts: 434 |
This is working correctly. It is being saved, but as a Parallel Ray config instead of a Parallel Line config. This happens because setting the extend forward option transforms the drawing into a Parallel Ray, and then when you save the config it saves as a Ray. You can see this in the title of the Chart Drawing Properties window. |
[2016-03-06 22:24:33] |
The documentation has been updated to explain this. First please always refer to the documentation because it contains a lot of information.
