Date/Time: Tue, 30 Apr 2024 14:44:06 +0000
Data Connection
View Count: 604
[2016-02-25 00:15:33] |
User866639 - Posts: 1 |
My data has ended according to Sierra. I have a trading acct. with AMP trading. My charts are suppose to be included. How can I reconnect?
[2016-02-25 03:02:17] |
Hello, We do not provide support for your particular question for users who have accounts provided by a Sierra Chart reseller or affiliate. You will need to contact the reseller or affiliate for help with this particular question. If you want to rely upon Sierra Chart support, we require that you have your own separate Sierra Chart account, which you may already have. If you want to use Sierra Chart, you will need to pay for usage time on that account. If you do not already have your own direct Sierra Chart account, simply follow through the step by step instructions here: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html To log into Sierra Chart with your own account if you are not using that one already, then follow these instructions: http://www.sierrachart.com/index.php?page=doc/LoginInstructions.php#DifferentAccountName Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
