Date/Time: Wed, 01 May 2024 09:37:20 +0000
Overlay chart in background refreshes : constantly (Ver 1366)
View Count: 777
[2016-02-19 15:58:15] |
User838334 - Posts: 6 |
Since last upgrade, overlay chart in background refreshes constantly. I have reversed version, tried new and old spreadsheets : does not change it. Uses more cpu resources and I am not sure if delays any thing on my chart drawing I.E : I have futures chart than I overlay tick.z chart (tick.z chart will refresh every second - screen will go black, redraw.) I am sending a log file to support about 11 AM ET |
[2016-02-19 18:07:53] |
Refer to help topic 30.3: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-24 16:00:43] |
Thanks.
