Date/Time: Sun, 28 Apr 2024 04:59:20 +0000
Nat Gas Chart Frozen
View Count: 2452
[2013-03-28 16:29:56] |
Please tell us the exact Symbol of the chart. You can see this in Chart >> Chart Settings for the chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-28 16:30:11
[2013-03-28 17:10:47] |
You posted images of 2 charts that were apparently from another user. They have been deleted. Either there was some technical problem and you did not post those images or we are confused as to why you posted them? They are not relevant to this because they involve another symbol. Please refer to help topic 3 here: http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-03-28 19:48:20] |
There is a communication problem here. Please have them open a chart by selecting File >> Find Symbol. In the Selected Symbol box enter the following symbol: NG-201305-CME Press Open Intraday Chart. After that if there is a problem, please provide an image of the chart, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-03 10:28:48] |
User28973 - Posts: 8 |
http://www.sierrachart.com/image.php?l=1364984851975.png |
[2013-04-03 10:32:27] |
Here I found that post a picture istavio daily chart and less time frame here http://www.sierrachart.com/image.php?l=1364985105408.png |
[2013-04-03 15:55:20] |
They are looking at the Natural Gas TAS chart. They clearly are not charting NG-201305-CME. None of these charts are for that symbol. For wheat, use the ZW-201305-CBOT Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-03 15:56:07
