Date/Time: Wed, 15 May 2024 16:10:50 +0000
CQG data for Osaka Securities Exchange and Tokyo Stock Exchange
View Count: 1791
[2016-02-01 22:20:13] |
User705691 - Posts: 22 |
I would like to use CQG with Sierra Chart to access live data from the Osaka Securities Exchange and Tokyo Stock Exchange. I contacted CQG and asked them for pricing, but they said that since I use Sierra Chart, only Sierra Chart can make this available for me and provide pricing. Do you provide data for these exchanges? I currently use IB as my broker, and their data quality is horrendous. Thanks. Date Time Of Last Edit: 2016-02-01 22:20:38
[2016-02-02 04:05:09] |
We need to ask CQG about this.
[2016-02-02 09:08:19] |
We are making progress on this. Just got this answer now from CQG: Yes, we support OSE and TSE also please see complete list of supported exchanges. Market data from all supported exchanges is available through CQG Web API.
This is the link they gave: http://www.cqg.com/partners/exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-07 18:19:45
[2016-02-02 11:15:49] |
Thank you! The only thing I am concerned about is the pricing. I will await any updates.
[2016-02-02 20:30:54] |
Still have not heard anything back from CQG about this.
[2016-02-07 18:18:46] |
This is the latest information from CQG: Its done by entitlement. The FCM can enable the market data from our database and then the trader should be able to get it
So to be able access these, you will need to open a trading account with a trading/broker service supporting CQG. We would also assume they would have to support trading in these particular exchanges mentioned. Not sure all of them would. We have asked CQG about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-12-02 13:22:11] |
User626121 - Posts: 82 |
Hi, I also use IB data for Osaka Exchange / TSE, especially JGB Futures, but their data is not quite accurate. I didn't find any broker offering JGB Futures with CQG. IQ Feed doesn't offer it, too. Esignal provides OSE/TSE, but I can't use SC with it. So my question: Would you consider providing access to OSE/TSE with your own SC Realtime Exchange data feed? JGB Futures and Nikkei 225 Mini Futures are the most liquid instruments of the Asian Session. Regards Date Time Of Last Edit: 2016-12-02 13:24:06
[2016-12-02 17:59:30] |
No we cannot consider this. The exchange fees make it next to impossible.
