Date/Time: Sun, 26 May 2024 02:27:16 +0000
non-functioning Sierra Chart
View Count: 713
[2016-01-22 19:04:46] |
rick e - Posts: 51 |
This morning I started up Sierra Chart version 1253 as usual and found the Toolbar near the top of the screen intact across the screen but NO TEXT of all things on the buttons only the information of which button it was by the mouse cursor pointer and when I opened a chart book, which was to be an update of a number of historical daily charts, the charts loaded but no updating took place even if I was connected to Sierra Chart. I have no idea what to make of this. Sierra Chart was working perfectly when I shut it off yesterday. Any input would be greatly appreciated. Thanks - Rick
[2016-01-23 09:34:40] |
To solve the ToolBar problem we recommend updating to the newest version of Sierra Chart following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate The ToolBar has been rebuilt and a problem like this is much less likely to occur. The reason for the problem is going to be an operating system level issue relating to the available memory to create bitmap objects. Refer to help topic 6 for problems with Historical Daily chart updating: Http://www.sierrachart.com/index.php?page=doc/helpdetails6.html In general, we recommend updating to Sierra Chart for us to properly help you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
